Acer 5738 SIO replacement
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear members,
    I am going to replace the WPCE773 chip by a new one on the mainboard of Acer 5738.
    Does the new WPCE773 require programming before soldering it onto the mainboard?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Acer 5738 SIO replacement
    This laptop originally has a bios chip model MX25L1605(SO8). Does it work if I replace it by another model W25Q16BVSIG(SO8)?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      WPCE773 is not programmable.
      Bios chip support-you need to check in bios descriptor region and then look for "Flash chips in VSCC table". Search the codes on google and you will get the flash chips supported.
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        Thanks,
        The laptop is old and its bios is not UEFI. So it has no VSCC table. How can I check whether W25Q16BVSIG is supported?
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          In the web, some people wrote WPCE773 and WPCE775 are compatible whereas some other people wrote they are not compatible.
          They are pin-compatible, but I am not sure they be functionally compatible.
          Have anyone successfully replaced WPCE773 by WPCE775 so far?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Originally posted by caspian
            Thanks,
            All bios has VSCC table. Open it in hex editor to found out. Yes UEFI tool wont work as bios is 2mb in size.
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              I opened the Bios dump in Hex Editor. But I cannot find the table. Maybe in has a different name in this Bios dump.
              The Bios dump is in this link:
              https://www.badcaps.net/forum/showpo...28&postcount=2
              • piernov
                • Jan 2016
                • 4437
                • France
                VSCC table is used for Intel ME and stored in the Flash descriptor. If there is no ME region and no Flash descriptor there won't be a VSCC table. Flash descriptor is mandatory since 5-series chipset for proper operation of the platform, not before as far as I know.
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  the chipset is GM45.
                  SIO is WPCE773.
                  I replaced MX25L1605D by MX25L1606. But it did not work. Laptop turns on but no display.
                  Is it possible that the Bios is programmed somehow to work only with MX25L1605D in Acer 5738?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Yes, possible. These old acer boards are very particular in bios chip support and usually support only 1 particular chip. However, you can try with other 2 mb chips available with you.
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      I tried two different ICs, W25Q16BVSIG and MX25L1606 with a known good dump, but they all resulted in turning on but no display.
                      The original Bios IC was MX25L1605D.
                        Acer Aspire A315-51-5738 Notebook 3 Specification for Upgrade or Repair
                        This specification for the Acer Aspire A315-51-5738 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-51-5738 boardview and A315-51-5738 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-06-2024, 06:48 AM
                      • 2Stupid4U
                        Acer Nitro 5 An517-51 mainboard short circuit - Boomer needs help
                        by 2Stupid4U
                        Laptop data:
                        NTB Acer An517-51 FHD
                        i7-9750H
                        16GB replaced with RAM Crucial Ballistix SODIMM DDR4-3200 32GB K2 SW
                        1TB SSD
                        RTX2060
                        Bon soir dear online techies, enthusiasts, modest helpers and whomever I might have forgotten!
                        Search gave me no hits so this is my first post.
                        My Acer 5 Nitro mainboard had a short circuit when I tried to plugin a USB device. Some smoke rose from the port and it became super hot a that point of entry/exit. Warranty was of about a month.
                        Since I am on a low budget I cannot afford to buy...
                        08-29-2023, 01:03 AM
                      • Mirenia
                        Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                        by Mirenia
                        I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                        I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                        In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                        The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                        03-30-2025, 06:47 AM
                        09-06-2024, 05:27 AM
                        Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                        This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                        09-07-2024, 05:00 AM
