Acer nitro Nitro 5 FH51M No Power
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    good day to all
    does anyone have an idea for this problem, I trace the Short on the system board to check the used schematic diagram.
    * thank satishkumar give us a schematic diagram. here is the link https://www.badcaps.net/forum/showth...87#post1136887
    now the problem I trace on +3VALW
  • mon2
    • Dec 2019
    • 14022
    Re: Acer nitro Nitro 5 FH51M No Power
    What is the voltage of +19VB ?
    Voltage on pin 12 of pu301 ? (3V_EN)
    Remove all power, meter in resistance mode.
    Check the resistance to ground of +3VALWP.
    • lorins_core
      BlackSmith
      • Dec 2012
      • 551
      • Philippines
      thanks i try later...
      • lorins_core
        BlackSmith
        • Dec 2012
        • 551
        • Philippines
        Voltage on pin 12 of pu301 ? (3V_EN) = Answer is 0.0V
        +3VALWP = Answer is 0 OHM (shorted to Ground)
        • mon2
          • Dec 2019
          • 14022
          Can you confirm the resistance scale used on your meter?
          Try the next high scale on the meter.
          There should be no power to the logic board with the resistance measurements.
          Confirm again this resistance to ground. With a 0 ohm reading, there is a hard short on this rail.
          • micsoria
            • Mar 2017
            • Philippines
            following this post. same problem with mine.
            • lpraderi
              • Dec 2017
              • 30
              • Uruguay
              Similar problem, 0 Ohms on B+ rail (19V).
              Lifted CPU VRM Phase Coils , short gone .
              ID Phase3 and Phase4 Output mosfets PQ8103 and PQ8104 (AON6962)
              Waiting for new ones.
              Datasheets:
              PCB: LA-F591P
              VRM RT3607CE
              MOSFET AON6962
              • mon2
                • Dec 2019
                • 14022
                This often means that the high side voltage of ~19v has hit the CPU and the CPU is now defective.
