Acer SF314-52 charging
  • adam2204
    • May 2018
    • 17
    • Croatia
    Hey guys,
    I got problem with Acer SF314-52. Problem is that laptop wont charge battery, I did put new battery which was on about 60%, and laptop was plugged all the time and battery went to 1%. Laptop is normally working on charger.
    I did try to replace first two mosfets --> same problem
    I did try to replace BQ chip --> same problem
    I measure that on coil next to the battery connector (which is connected with + of connector) I got about 3,5V.
    I don't have idea anymore, what is next to check?
    Tnx
  • mon2
    • Dec 2019
    • 14138
    Re: Acer SF314-52 charging
    1) is the battery pack detected ?
    2) what is the voltage of +BAT_CON with the battery & adapter connected ?
    3) Remove all power. Meter in DC volts scale. Measure the voltage of +BAT_CON (without adapter connected).
    Is the reading of the coil L8800, pin # 2 ?
    What is the reading in volts ?
    4) Also measure the voltage @ AC_BAT_SYS with the battery only connected.
    • adam2204
      • May 2018
      • 17
      • Croatia
      1.) yea battery pack is detected
      2.) +batt con with ac adapter plugged in is same as without ac adapter. (it is battery voltage, I did try with serveral batteries, and did try all of that batteries in other Acer and they all work normally)
      3.) yea on coil L8800 I got 3V with battery disconnected and charger plugged in.
      4.) bat_sys with just battery 15.08V and with charger connected is jumping from 15.08V to 19.67V every second
      • mon2
        • Dec 2019
        • 14138
        This is ok since you do not have a battery connected so no job to do..
        1) Attach the battery and the adapter. What is the voltage @ L8800, pin # 2?
        2) Your battery is showing a voltage ~15.08V which is ok.
        3) Remove all power (no battery) -> meter in resistance mode.
        Check the status of the battery mosfet @ Q8802 as follows:
        source (1-2-3) & drain (5-6-7-8)
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Post your measurements and the meter scale used for each. If you see '1' on the meter, switch to the next higher resistance scale.
        We are checking for a low resistance which often means the mosfet is defective.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          What is the platform name?? DC in fets Gate voltage??
          • adam2204
            • May 2018
            • 17
            • Croatia
            source (1-2-3) & drain (5-6-7-8) 165k Ohm
            source (1-2-3) & gate (4) 5,9M Ohm
            gate (4) & drain (5-6-7-8) no reading (did try 100 times)
            Try to replace it or that's normal?
