Re: Toshiba Satellite L750D - 19v missing on the main power rail
We are not trying to burn anything but to locate (by the dissipated heat) the component that causes the short circuit in the line, if it was certain that it was a capacitor we could easily increase the voltage, but we are not. The short circuit can be caused by a consumer of some switching power supply, and if the upper mosfet in that power supply is shorted for example, and we apply a higher voltage to the consumer (through the shortened mosfet) from which it is designed to work, it can burn out. So we will have to limit the voltage to safe 1v to make sure it won't get damaged if this is the case eventually.
