Battery not charging faroe_dis_x32_mb_mv laptop motherboard
  • ahmarzo
    • Mar 2015
    • 173
    • india
    I have faroe_dis_x32_mb_mv laptop motherboard. Problem is battery not charging. Have replaced charging ic bq24780s and tried new battery. Both old and new battery shows 0v backup.
  • mon2
    • 14667
    Re: Battery not charging
    hey!
    1) review the datasheet from TI for this charger IC.
    2) the logic board will be a 99% clone of the reference schematic.
    3) then study the battery mosfet. With NO power - confirm the resistance of this mosfet (see the many posts from myself and others) - you are checking for a low resistance across the mosfet pins = defective mosfet and needs to be replaced.
    4) Do check the HIGH SIDE / LOW SIDE mosfets that are feeding the battery charge pins.
    5) Next, confirm with the adapter of the voltage that is at the battery pin. What do you see ?
    6) Do note, as we have seen it here before, the CURRENT sense resistor and circuit on this charger IC. The case took 3 weeks to solve but there was a broken PCB trace from the current sense resistor TO the charger IC. This caused the charger IC to believe too much current being drawn and forcing the rail to sink to 0 volts => shut down the charging leg of the IC !!
    Check without power, the resistance from each side of the current resistor TO the respective pin on the charger IC. The readings should be ~0 ohms.
    Post relative readings of questions.
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • cope
      Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
      by cope
      I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
      Some history:
      Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
      As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
      Now, with a new battery the system will start up and run off...
      05-13-2024, 09:40 AM
      Bauer tool battery pack charging with a HERCULES charger modification
      The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
      Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
      05-06-2023, 12:17 PM
