dell e5550 not posting
  • coltron
    • Jan 2021
    • 98
    • England
    Hi, hope someone can help diagnose a dell E5550,
    Mobo LA - A911P Rev 1
    which refuses to post.
    When received, the laptop powered on, but gave a light code indicating ram issue. The ram and slot were cleaned, then ram re-seated.
    Now laptop powers on with no error codes or beeps, but wont display to lcd or hdmi.
    When a usb win10 installation stick is present at boot, there is no sign of power or communication with it.
    I have the board out and have inspected components for obvious damage/liquid ingress but found none.
    pl700 = 19.5v
    PL701 =13.5V
    these get warm, but not hot hot
    processor grease was dried out and has now been re - pasted.
    Fan spins high when on button held in for shut down.
    pl101 3v and pl102 5v are present
    pl200 1.35v present
    pl500 2.04v
    pl301 1.05v
    Anything to check before pulling the bios chip?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: dell e5550 not posting
    Check whether DRAMRST# is present??
    • coltron
      • Jan 2021
      • 98
      • England
      Thanks mcplslg.
      Assuming dramst not present, is the laptop toast?
      • coltron
        • Jan 2021
        • 98
        • England
        dramst fine, I've got another board rather than chase the fault, but put to one side for a Rainey day....thanks mcpisig123...i think i will wait till i have a few boards and do a few bios dumps in one day
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • chaos_prevails
          Dell Latitude E7470 i7: no TPM + TXT in BIOS/Firmware (but chip is present on the motherboard)
          by chaos_prevails
          I've purchased 2nd hand Dell Latitude E7470 i7-6600U and it works fine, except ... there are no TPM or TXT/Trusted Execution settings in the BIOS/Firmware. However, looking at the schematics I found the chip handling TPM (NPCT650JA0YX) soldered to the system board. Also, looking at the service tag and the product specifications, this device comes with TPM (and vPro) support (I know that devices sold in China, Russia are not allowed to ship with TPM but this should be reflected in the service tag). I can also login to MBex to configure, etc.
          In the produce specs...
          02-12-2024, 05:21 AM
        • re1nhold
          Bios needed, Dell E5550, Tag FSFB262, Zam80 La-911P Rev.1
          by re1nhold
          Hello Guys
          I'm currently fixing two different Dell latitudes,
          I need a E5550 BIOS - SERVICE TAG is: FSFB262
          So far I flashed about 6 BIOS from this forum already,
          none worked,
          only fan spin ~3s, LCD black, keyboard LED on/off ok,
          I tried manual extraction with scripts for ages so to speak. VM is untried yet.
          This laptop is not burnt, it seems to just have a corrupted BIOS.
          I extra baught ram. This has to work friends.
          Do you generate it this way in Windows in CMD?:
          Code:
          E5550A24.exe /writeromfile C:\bios.fd
          07-18-2025, 09:18 AM
        • Eradicatus
          Dell Latitude E5550 - Strange Internal LCD (BIOS?) Issue
          by Eradicatus
          I have a problem with my Dell Latitude E5550 laptop, in particular with its display.
          This laptop has been sat under my desk (unused) for quite a while and I wanted to reinstall Windows and use it for some ad-hoc testing.
          However, I am struggling with the display, which is playing up.
          1) When the laptop is left switched off, after switching it back on the internal LCD does not work. No images are displayed at all - no DELL logo on POST, no messages, no Windows desktop. But I can hear that Windows starts up correctly, so no issues with the rest of the system - must be...
          04-20-2022, 02:40 AM
        • lapfix
          Dell Latitude E5550 LA-A911P no complete power on !
          by lapfix
          First the lap come witth a short to GND , it was a faulty capacitator : PC716
          After desoldered , the lap works fine...but after some tries not power on.
          Power supply reach 0.159amp for 1 minute than off...no short to GND at all coils .
          All the voltages at PM TABLE are finded , try another bios same behaviour !
          PS id is oK ; i try with an original charger same behaviour too...
          PQ700 a P-channel is ok , but his gate is not correct..0.001v...
          Pin 5/8 = 19v
          Pin1/3 = 19 v
          Pin 4 = 0.001v...not correct.
          Pu 800 =
          Pin...
          07-29-2024, 06:05 AM
