HELA15_N18E_130W :What are those components ? Resistors or capacitors and what value
  • madfreak
    • Aug 2012
    • 133
    • Poland
    Hi You all, i have mistakenly lost few components while soldering mosfet and because there is no schematic for that board i do not know what those components in yellow circles are
    If someone know the name of the components and values i will be really appreciated.
    The laptop name is :
    DELL G7 17 7000
    GTX 1660Ti
    i7-10750H
    And the board name is :
    HELA15_N18E_130W_MB
    Best of luck to You all and thank You in advance for help
  • elecsoluces
    • May 2020
    • 66
    • France
    Re: Please help :What are those components ? Resistors or capacitors and what v
    It's a coil 0.15µH
    • JaroTech
      • Mar 2015
      • 351
      Originally posted by elecsoluces
      It's a coil 0.15µH
      The question is not for the coil (red circle), he was asking what are the three components in the yellow circles above the coil!
      • mon2
        • Dec 2019
        • 14065
        Re: HELA15_N18E_130W :What are those components ? Resistors or capacitors and what va
        What are the markings on the topside of each black component that are north of each inductor ? From a distance, this looks to be a multiphase power supply that work to power some hefty current device (GPU is most likely the pig).
        On the missing parts - remove all power.
        Meter in resistance mode.
        Then place one meter lead on the missing part pad; the other meter lead on the larger cap that is nearby. What is the resistance ?
        Trying to determine if the missing parts were in parallel to the nearby part.
        In this case, the part will be despike / filter cap - different values are used to filter different frequencies.
        For example, often in our PCB designs, we will use:
        0.1uf + 0.001uf + 10uf on a power rail. Different cap values help in different ways to filter out noise on that power rail. Multiple caps on the same leg will also allow them to share the burden (current) of the heavy load (work).
        Repeat the resistance check with the meter on the OTHER side of the missing part's pad; then the meter lead on the OTHER side of the nearby part. This is only to check if the missing part was in parallel, like above testing.
        • madfreak
          • Aug 2012
          • 133
          • Poland
          Thank You, they are all 0,1 uF/25V = 100nF/25V and the size is 0201.
          Nooooo way i will solder that dust hehe ... i will place 0603 at least.
          • mon2
            • Dec 2019
            • 14065
            You can even skip mounting them. These caps will not be missed.
            If you really want to mount them, consider to buy leaded (aka through hole) caps and solder them onto the larger caps. Just trim the legs to suit - make them short as possible and solder them 'piggy back' style.
            This cap value will not be polarized so they can be soldered in either direction / orientation.
            • madfreak
              • Aug 2012
              • 133
              • Poland
              Everything works fine i think
              • Sam Scarbo
                Sparkle 1200W PSU MAGNA Model: SPM1200AXJ8 - Broken. Need help identifying components. Any schematics available?
                by Sam Scarbo
                My Sparkle (SPI) PC power supply has broken. Originally, there was totally no power output. The 5V-standby was not there. I have replaced a few bulged capacitors but not helping.
                I was trying to do more troubleshooting but burned more components. Some got burned so badly that the markings were gone. And also, the markings of a few transistors were gone because the component surface was worn out somehow.
                If you happened to have disassembled the same PSU model, please help to provide the markings of some of these components.
                See the attached two pictures of the small...
                09-18-2024, 08:29 AM
              • TinkerTron
                Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                by TinkerTron
                Hey everyone,
                I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                Instead, here's what's been bugging me so far:
                The schematic...
                03-06-2025, 02:03 PM
              • User2025
                Please help to identify the components on Surface Laptop GO3, model 2013, i5-1230U
                by User2025
                I am working on a Surface Laptop GO 3, which is the new release 2024 with a i5-1230U processor. Originally, it had a 256GB SSD, then the owner attempted to upgrade it to 1TB SSD by himself. "Surprisingly", it did not boot afterwards, then changed back to the original SSD, did not boot either.
                It turned out to be that just a couple of components had been knocked off when the owner was trying to get off the SSD cover with his beloved screw driver.
                I do not have another board of same model. Although I have a Laptop Go 2, the layout of that bit...
                04-29-2025, 04:13 PM
              • Endlessmist
                Surface Pro 4 - need help with some messed up components
                by Endlessmist
                Hi everyone
                Here is the case that i'm trying to solve.
                (short intro to explain what happened)
                I bought second hand Surface Pro 4 and when I tried to reinstall the Windows it appeared there was the password on UEFI. Seller don't reply anymore. I decided to reflash the UEFI chip to remove the password. So I need to remove the chip from the motherboard first.
                I have basic experience of repair tablets and phones, like battery or display change. So i opened the Surface Pro 4 and removed the motherboard successfully.
                (the...
                04-22-2023, 07:30 AM
              • alindumitru46
                Gigabyte Windforce 980 G1 Gaming no image
                by alindumitru46
                I received the board as a "souvenir", but from the first analysis it was full of dust and lint, never maintained, for sure.
                The exact model is GV-N980G1 Gaming-4GD rev 1.0.
                The board starts with the fans running full, the blue Windforce LED is on, but it doesn't give any image at all, and the GPU is cold.
                I moved on to disassembly and cleaning, unfortunately for some time I haven't been able to keep a better photo device handy and the pictures are not great.
                I quickly identified an area with 2 oxidized resistors, R61/R64, and after carefully cleaning the 2 resistors...
                01-25-2025, 07:14 AM
