dell inspiron N5050 3v,5v alw no present
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    good afternoon all my colleagues, I hope that on this occasion someone can guide me to overcome this DELL INSPIRON N5050 mobo, the problem is that there is no voltage on the 3v and 5v coils, and after I saw the schematic of this mobo, it uses IC TPS51123 and I have measured the important points on this ic pin, and this is the measurement result:
    VIN : 19V
    VREF: 1.8V
    EN0 : 1.3V
    VREG3; 3V
    VREG5 ; 5V
    ENC: 1.3V
    ENTRIP1 & 2: 0V
    I've already done flash bios but it's still the same
    Thank you for your attention, I also attached the schematic for this mobo
  • mon2
    • 14662
    Re: dell inspiron N5050 3v,5v alw no present
    Which IC are you referencing ? PU4103 ?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      This mb has Nuvoton KBC and PSL Logic is involved here and often is the cause of no volts on 3/5V coil. I hope you can move on from this clue.Btw, is the 3/5V PWm getting Hot??
      • Udemzy
        • May 2017
        • 164
        • Guatemala
        Follow the PSL logic but then your ENC is generating but it is low 1.3v, after ENC is released you Will get volt on Entrip before 3.3v/5v coil will generate.
        Trace back ENC pin
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          As mcplslg123 mention before take the voltages at this pins and post it here
          U2701A page 27 :
          PSL_IN2 pin 93
          PSL_IN1 pin 73
          PSL_OUT pin 74
          S5_ENABLE pin 14
          • Yosua
            • Jun 2021
            • 221
            • Indonesia
            Yes sir youre right , the ic is geting hot
            • Yosua
              • Jun 2021
              • 221
              • Indonesia
              U2701A page 27 :
              PSL_IN2 pin 93
              PSL_IN1 pin 73
              PSL_OUT pin 74
              S5_ENABLE pin 14
              thank you for all the advice sir, and this is the measurement result
              PSL_IN2 pin 93=0v
              PSL_IN1 pin 73=0v
              PSL_OUT pin 74=2.9v
              S5_ENABLE pin 14=1.1v
              • Yosua
                • Jun 2021
                • 221
                • Indonesia
                IC 3v and 5v sir namely TPS51123
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Q2704-Voltage on all pins(located near SIO)?? Most probably its bad. Its a P channel mosfet.
                  • Yosua
                    • Jun 2021
                    • 221
                    • Indonesia
                    but this transistor is empty sir, does it matter?
                    • Yosua
                      • Jun 2021
                      • 221
                      • Indonesia
                      this is the measurement result of pin q2704
                      g : 3v
                      s : 0.04v
                      d : 0
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Q2705 is there on mb?? If yes, voltage on all pins.
                        • Yosua
                          • Jun 2021
                          • 221
                          • Indonesia
                          I'm sorry if it took me so long to reply to this message, because now we are celebrating the big day here, this is the measurement of pin q2705
                          s = 0
                          g=3v
                          d=0.34v
                          I think this is normal?
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Sorry, i asked to measure at wrong place. Measure voltage on Q2703/Q2706
                            • Yosua
                              • Jun 2021
                              • 221
                              • Indonesia
                              this is for measurement
                              q2703
                              s = 3.26v
                              d = 3.27v
                              g = 0v
                              q2706
                              d = 0.96
                              s = gnd
                              g = 0v
                              • Yosua
                                • Jun 2021
                                • 221
                                • Indonesia
                                any one can help me,?
                                iam so confuse with rhis trouble on this mobo
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Q2706 Drain voltage is wrong at 0.96V. It should be 3.3V. Its pulled up from 3D3V_AUX_KBC and that voltage is present going by your measurement on Q2703. Check voltage on R2714-both sides. Voltage on pin14 of SIO??
                                  • Yosua
                                    • Jun 2021
                                    • 221
                                    • Indonesia
                                    for measurement on pin 14 kbc is 0.72v - 1.21v unstable sir, and sorry I didn't find a resistor with code r2714 on the mobo, I think I need boardview
                                      DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      09-12-2024, 03:36 PM
                                      DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      09-12-2024, 03:30 PM
                                      DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                                      09-12-2024, 03:28 PM
                                      DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
