MacBook Pro A1286 Mid 2012 no backlight but display working
  • Gigabit2
    • Apr 2022
    • 264
    I have a MacBook Pro mid 2012 with no backlight but the display is working. Have shined a light through the Apple logo and can see the display working.
    This is my first time doing one of these repairs so my apologies for anything stupid I say or anything obvious I miss
    Board is 820-3330-B.
    F9700 is showing 3.3V on both sides of the fuse, I believe it should be 12.6V?
    Now I have got stuck, what can I inspect next?
    Many thanks.
  • mon2
    • 14636
    Re: MacBook Pro A1286 Mid 2012 no backlight but display working
    So PPBUS_G3H = 3v3 ? This is not correct for a good board.
    Check for the presence of fuses @ F7040 & F7041.
    Remove all power. Meter in resistance mode (lowest scale).
    Check for the resistance to ground @ F7040, pin #1 or # 2.
    We are checking to see if you have a low resistance = bad cap on this rail ?
    If the resistance is not too low, remove F7040 & F7041 (if present) off the logic board. Then power up again.
    Check the voltage of PPBUS_G3H @ F7040, pad # 1 on the logic board.
    Do you see a higher voltage for PPBUS_G3H ? Post your readings.
    • Gigabit2
      • Apr 2022
      • 264
      Am seeing 12.5V after removing F7040 and F7041
      • mon2
        • 14636
        Remove all power. Meter in resistance mode.
        Check for the resistance to ground @ F7040, pin # 2 (the other side of this fuse) = consumer side. We know that pin # 1 of this fuse = producer side is OK.
        Red lead on this pad; black meter lead to ground.
        What is the resistance ?
        So far, we know that U7000 is OK.
        • Gigabit2
          • Apr 2022
          • 264
          Resistance showing 1 . on multimeter display with lowest scale set.
          • mon2
            • 14636
            That likely means that the scale is too low to measure the resistance.
            Increase the scale till you have a reading. Then post the scale setting and reading.
            • Gigabit2
              • Apr 2022
              • 264
              With scale at 2M, seeing .046 on pin 2
              • Gigabit2
                • Apr 2022
                • 264
                Hi @mon2 is the above enough info
                • mon2
                  • 14636
                  Yes. The resistance looks ok.
                  Install back the fuses @ F7040 & F7041.
                  Remove the fuse @ F9700 (backlight fuse).
                  Power up again. What voltage do you read @ F7040, pin # 2 ?
                  Confirm that the same voltage appears at the removed F9700, pin # 1 pad.
