ASUS ROG G14 (GA401) battery spark, dead.
  • Stevedb
    replied
    Re: ASUS ROG G14 (GA401) battery spark, dead.
    Hi what are the voltages on the charging ic now?
  • jacobtc
    replied
    UPDATE:
    Replaced the DC-in mosfets and charging IC, and the machine now boots, but only when AC is plugged in. So I managed to fix the AC charging, but the machine turns off when unplugged. The battery charging diode is showing, and the machine seems to detect the battery just fine, but when unplugged, it immediately dies... I have somehow reversed the issues the machine had, when I got it, it would boot fine with only the battery, but would not charge, now the machine boots with AC, and seems to charge, but dies when unplugging it... I'm pulling my hairs out..
    EDIT:
    Checked battery voltage with MM, and it seems completely dead, even though Windows says 99%, gonna let it be plugged in for a while and check if voltage increases...
  • Stevedb
    replied
    These are the most important pins from the ic.
    Regards
    Steve
  • Stevedb
    replied
    Yea i do not understand it too maybe not good charging ic. Or the first and second mosfets are bad because ac drive should be 25 v . If you don't have a short what it can pull down at signal i would think maybe a bad replacement ic if you soldered right. I would track down that signalto the first and second mosfet gates.
    Good luck
    Keep me posted
  • jacobtc
    replied
    Originally posted by Stevedb
    Is the latop fixed now?
    Regards
    Hey Steve, sadly no, I haven't had an opportunity to look at it, and have only done what I wrote in the last post. Still having hopes that this can be fixed, it just bothers me that it is completely dead now, where as before it actually could boot, but not charge through AC.
  • Stevedb
    replied
    Regards
  • jacobtc
    replied
    Okay, I'm back after meassuring stuff.
    Did measurements on the new mosfets at the charging IC area, both on and off the board. I also did diode reading on S-D, and both mosfets came back with 0V when on board, but 0.4V when off the board, is that normal? Checked the mosfets at the DC-in area, and they both came back at 0.6V on the board.
    Resoldered the charging IC area mosfets, and they again came back at 0V. Did a diode check on the pads underneath the mosfets, and they also came back at 0V, is that the culprit or?
    OH yeah, and about the "non-readings" at the DC-in mosfets... turned the probes arund, and they gave me 4.6Mohm and 5Mohm then.
    Before I desolder the DC-in mosfets, I just wanted to ask about this first, they do seem fine checking in diode mode, and I haven't touched them, and the laptop turned on fine, before I touched the charging IC area and surrounding mosfets, which is why I doubt they could be the culprit.
  • jacobtc
    replied
    Originally posted by mon2
    Do you have more replacement mosfets for the pair near the dc adapter connector?
    Measure each while they are out of circuit to compare with the earlier measurements. Post the readings.
    The concern is with the one reading of each where the value could not be measured. Is the reading so high for the meter scale or maybe an open circuit?
    Mosfets are ESD sensitive so be sure to be grounded while working with them.
    I have replacements for all mosfets yes.
    I will desolder all and measure them off the board.
  • mon2
    replied
  • jacobtc
    replied
    Measure in the same way as before, the replacement mosfets but while they are out of circuit with your meter in resistance mode.
    What are the readings for the new mosfets?
    Since you have the fresh mosfets, consider to replace the older ones on the logic board.
    Replace the first mosfet and take care on the pin #1 location of the device.
    Allow the mosfet to cool down. Do not power on. Then check the mosfet resistance again when in circuit.
    Post the readings of the new mosfet while in circuit.
    Then repeat for the 2nd mosfet.
    Lots of flux and with patience so no pcb pads are lost in the process.
    So I should desolder the "new" mosfets again, and meassure them? Then replace the mosfets at the DC-in area?
  • mon2
    replied
  • jacobtc
    replied
    yOU DIDNT MENTIONED VOLTAGE ON ACN/ACP pins. I think its zero on pin1-2-3. In other words, voltage is not paasing out from dc-in mosfets. Have you checked them for short??
    Both ACN and ACP is at 4.2V
    The second DC-IN mosfet only outputs that 4.2V, but resistance on those two mosfets checks out fine according to user "mon2".
  • mcplslg123
    replied
  • jacobtc
    replied
    Also AC drive should be 25 V
    Well it isn't
  • jacobtc
    replied
    Maybe the center ground pad is not making it to the PCB surface ? Usually we use tweezers to push down to squish the IC a bit to force the connection. Just be careful to not let the IC slide. Otherwise, very nice soldering of the QFN packaged device.
    Just know from being on the XMOS forum - their audio ICs had this as a #1 issue - key clients of their silicon could not get their protos working. Each time, it was the CENTER pad that was not mating with the PCB surface.
    I can give it a reflow again, but I already pushed down when soldering it the first time.
  • jacobtc
    replied
    Voltage on REGN pin # 24 ? What is the reading ?
    Your ACOK = 6v so I think you are ok with this charger IC....wait.. do you not have a resistor based voltage divider to lower this voltage for ACOK ?
    Were any surrounding parts disturbed or replaced ? Not sure if ACOK should be this high of a value..often the value should be lower, perhaps ~3v.
    REGN is 6V.
    Don't know about a voltage divider, the surrounding components were not replaced, and do not look disturbed, pretty sure I did not loose any.
  • mon2
    replied
  • Stevedb
    replied
    Double post
  • Stevedb
    replied
  • mon2
    replied
