2012 macbook pro with an encrypted volume
  • kjchatman
    • Dec 2012
    • 200
    • united states
    i have an older client that ended up getting his 2012 non retina macbook pro hacked. the hacker must've taken over and turned on the filevault feature. Can anyone tell me what his options are for recovering the data?
  • reformatt
    • Feb 2020
    • 1414
    Re: 2012 macbook pro with an encrypted volume
    Filevault is linked to the users login password. You can reset the password if the laptop is linked to the users Apple account.
    • kjchatman
      • Dec 2012
      • 200
      • united states
      the hacker turned on the filevault. Is this the end of the road for trying to get the data back?
      • reformatt
        • Feb 2020
        • 1414
        Boot into recovery mode and see if it will allow you to enter a password to unlock the volume. If the password is unknown, then only option is to try and reset via Apple account. I'm not aware of any unlocks for Filevault (doesn't mean there aren't any, just not my line of work).
        You can always restore the last Time Machine backup they have if they have one.
        • Rezendes
          Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
          by Rezendes
          Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
          I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
          The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
          05-10-2024, 02:18 PM
        • korben_dallas
          Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
          by korben_dallas
          Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
          I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
          I'm new to soldering but the only feasible way to fix this issue is to do something myself.
          MY QUESTION:
          I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
          02-14-2024, 12:23 AM
        • bastien
          OBDATA Raccoon Computer V1 for Macbook Pro Air 2012-2025
          by bastien
          It's the end of three years of work, it costs money, it costs time, and you owe me a beer.
          This is the new database for FlexBV
          it's optimized to work with it
          by using board ID has Default name, give us the opportunity,
          to use other diode board data with sibling board or family board
          I Merged the whole data (optimal)
          A2991 A2992 M3 -> -> 2 Entries diode data M1
          A2681 A3113 A3114 M1 M2 Air -> -> 2 Entries diode data M1 M2 13"
          A2442 A2485 A2779...
          03-18-2025, 08:03 AM
        • envym
          by envym
          Hi everyone!
          06-27-2025, 08:54 AM
        • tobeend
          Bypass mdm macbook m2 ventura
          by tobeend
          1. RESET MACOS WITH IPSW
          a. Power off MacBook, press and hold the power button to enter Recovery
          b. Open Disk Utility, remove Macintosh HD
          c. Reboot, connect to the network to Activate Mac.
          d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
          d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
          e. Release the other keys, but keep holding the Power key for another 10 seconds
          f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
          05-26-2023, 07:18 AM
