Lenovo L580 not posting
  • coltron
    • Jan 2021
    • 98
    • England
    Hi , I have a lenovo l580, which won't fully post.
    When the power button is pressed, the laptop begins to boot, but stops short of screen coming on , (without beeps).
    Then keyboard caps lock light illuminates but won't toggle on/off
    Fan spins up and down, and after a minute or 2 revs up and won't rev down again
    and that's all...
    nothing on HDMI
    Tried disconnecting laptop's keyboard and using external usb type, but the keyboard shows no life and has no influence on the laptop.
    When ram is removed the laptop will beep correctly to identify missing ram.
    Tried known working RAM but the problem persists.
    No shorts on the supply coils, but the 2nd usb type c socket is not working i.e. charging adaptor has no effect. ( works on my other l580).
    Stuck a usb stick with ububtu on it, the stick remains inactive.
    I have a second working laptop and to date have found no voltage anomoly?
    I,m trying to follow the power on sequence in the schematic attached but having difficulty grasping the concept, if you know what i mean.
    Any help /guidance would be greatly appreciated.
  • rediii
    h???, spurrrn
    • Mar 2018
    • 501
    • somewhere in europe
    Re: Lenovo L580 not posting
    and that's all...
    nothing on HDMI
    did you try to reflash a working bios? does the cpu power up? core rails present? so you have a usb c meter for checking how many amps the machine is drawing?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      DRAMRST# present??
      • coltron
        • Jan 2021
        • 98
        • England
        Thanks for replies
        Rediii, In terms of bios, I haven't attempted a re-flash, until I'm satisfied no hardware fault exists, but is certainly an option thanks. I have no means of determining amps drawn unfortunately,
        i get 9.1v at the CPU Mosfets The cpu gets warm. core voltages
        PL403 - No volts
        PL406 - 2.7
        PL411 - 2.8
        PL408 - 1.4
        PL610 - 2.6
        mcpisig123, I'm unfamiliar with DRAMRST, but i'm here to learn.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          DRAMRST#- you can measure on ram slot pin#30(Assuming DDR3 ram module is being used)
          • coltron
            • Jan 2021
            • 98
            • England
            Thanks, I have DDR4?, would i be looking for a certain voltage?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Check Ramslot pin108 for DRAMRST# for DDR4. It should be 1.2V
              • coltron
                • Jan 2021
                • 98
                • England
                Thanks, first time probing ram, is there a safe way to check without shorting to pins either side?
                • coltron
                  • Jan 2021
                  • 98
                  • England
                  dramrst is present on DRAM Socket pin 108 at 1.23v.
                  I'm assuming that's good..
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Yes. That's perfect
                    • juergenb
                      • 42
                      maybe these value will help.
                      PL201 +3VLX
                      PL202 +5VLX
                      PL403 +VCC_GT
                      PL406 +VCC_Core
                      PL411 +VCC_Core
                      PL408 +VCC_SA
                      PL610 +1VALWP
                      PL301 +1.2VP
                      U0901.8 +3V_SPI
                      U4502.8 VCC_3LD0_PD_SPI
                      I have a L480 with no Post, only Power LED/Thinkpad Dot flashing (3 Times) and i try to diagnose this board.
                      This board has no +3V_SPI on Bios Chip ... (25Q128JVSIQ_SO8)
                      I will check PL201 (open PJ201/PF202) if there is some short to ground
                      • coltron
                        • Jan 2021
                        • 98
                        • England
                        Hello Juergenb, In terms of next step, I'm open to all suggestions, and intend to check the thinkpad dot as soon as i connect the board up to the ThinkPad display.
                        Out of curiosity, does the keyboard caps lock freeze on your l480?
                          • 21915
                          Whats the voltage at S3 TAMPER_SW_DTCT
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Thanks for replies
                            PL403 - No volts
                            PL406 - 2.7
                            PL411 - 2.8
                            PL408 - 1.4
                            PL610 - 2.6
                            Are you sure about these measurements?? How can a 1ALWP coil read 2.6V?? Measure all coil voltages again. If you have not flashed bios, flash it with known good clean me bios.
                            • rediii
                              h???, spurrrn
                              • Mar 2018
                              • 501
                              post the bios here, we can clean the me... (coltron )
                              • rediii
                                h???, spurrrn
                                • Mar 2018
                                • 501
                                pls open new thread in bios request forum, i think that's better !
                                • coltron
                                  • Jan 2021
                                  • 98
                                  • England
                                  Checked the ThinkPad status light and that's solid red.
                                  Big discrepancy in the voltage measurements compared to Juergenb's chart and highlighted by mcplsig123.
                                  Re - measured voltages are:-
                                  PL403 - No volts
                                  PL406 - 1.2
                                  PL411 - 1.2
                                  PL408 - 0.74
                                  PL610 - 1.1
                                  Unsure of initial readings cause, but assume my voltmeter needs replacing since all readings were consistently wrong.
                                  SMDFlea - Tamper switch reading (sw open) 2.75v pch / 0v s3
                                  With regards Bios flash - can I/we assume CPU and memory are Good at this point?
                                  • coltron
                                    • Jan 2021
                                    • 98
                                    • England
                                    Thanks rediii, will open a bios request once I've blown the dust off my programmer
                                    • coltron
                                      • Jan 2021
                                      • 98
                                      • England
                                      However, I have a working l580, with i5cpu, could i copy that bios for the faulty machine with an i7 cpu?
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        You can but the me region of the bios has to be cleaned before flashing it on another pc.
                                          Lenovo ThinkPad L580 Notebook L Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad L580 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L580 boardview and L580 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 02:28 PM
                                          09-06-2024, 11:17 AM
                                          09-06-2024, 09:09 AM
