Lenovo B51-80 green led flashing shortly
  • darkm4n
    • May 2021
    I am trying to repair a dead Lenovo B51-80 laptop, currently with the battery connected it doesn't power on, it's completely dead, when I connect both battery and charged the green led near the DC input connector stays on but the green led from the bezel stays on for about 2..3 seconds than quickly flashes once than again stays green for another 2..3 secs and the sequence is repeating itself, the laptop does not power on.
    I did search for a schematic/boardview and could't find any and I don't have much experience with Lenovo laptop boards. I could't find any short on a quick look and also no visible damaged parts.
    Does anyone have any ideea that could point me in the right direction ?
    I believe the charging and power circuit is similar to the B50.
    Thanks!
  • mon2
    • 14664
    Re: Lenovo B51-80 green led flashing shortly
    Hi. There are many B50 schematics in my database.
    Can you identify which schematic you are referencing ?
    LA-B091P ?
    LA-B092P ?
    LA-B101P ?
    LA-B102P ?
    and there are others...
    • darkm4n
      • May 2021
      Hi mon2,
      This is a B51-80, not a B50.
      I did find a schematic online for B51-80 but it seems it's missing the charging circuit and boardview is not available anywhere.
      Thanks!
      • mon2
        • 14664
        We don't need no stinkin schematics...review where the DC adapter mates to the logic board.
        There you will see (most likely) 2 large mosfets and a charger IC nearby.
        Post the markings of the mosfets & charger IC that will be linked to these mosfets.
        First, is your battery known to be good ? What is the history of this unit ? Just decided to not work or liquid damage ?
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • JDong
          Problems flashing BIOS for supervisor locked Lenovo V15 G4 IRU 831A laptop
          by JDong
          There was an error... Aborting......I'm using another Linux Laptop with Zorin OS...to try and patch my Lenovo V15 G4 IRU with above specs....It originally had Windows 10/11 installed and converted to a dual boot Kali OS/Parrot OS system. I may have used the wrong lenovo_autopatcher_0.2 (I believe was posted by @knucklegrumble....I am out of ideas and flat broke so i cannot afford another fix (spent it all as an e-com entrepreneur does) any help from anyone would be GREATLY appreciated.....
          • Laptop Model: Lenovo V15 G4 IRU
          • Issue: Forgotten supervisor password.
          • BIOS Chip: GD25B128E (or GD25B128B
          07-06-2025, 10:18 PM
        • B2L_Repairs
          Lenovo g50-80 charging led flashing but laptop not switching on
          by B2L_Repairs
          I got a lenovo g50-80 that shows charging led (orange LED flashing) and when I press the power button the white LED comes on but the laptop doesn't switch on. The fan spins for 2 seconds when I press the power button then it stops. This problem started when my charging dock broke the connecting wires and i soldered these wires back but I might have mixed them. I ended up buying a new charging dock but laptop never switched on it just shows flashing orange LED when charger is connected. Could the super io be bad? I don't know how to go about diagnosing and I can't check any board view since this...
          01-19-2025, 12:28 PM
        • STKR123
          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
          by STKR123
          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
          I wonder if re-flashing the BIOS might be of any use here.
          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
          11-03-2024, 06:58 AM
          Lenovo 3000 Series Schematic
          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
          3000 C100 laptop with Braille keyboard
          Lenovo 3000 C
          C100, C200 - 15-inch XGA screen
          Lenovo 3000 N
          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
          N500 - 15.4 inch screen.
          Lenovo 3000 V
          V100, V200 - 12.1-inch WXGA models
          Lenovo 3000 G
          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
          10-04-2024, 06:05 AM
