Acer a315-25-95kf
  • String2016
    • Nov 2015
    • 2234
    • philippines
    Acer a315-25-95kf
    I need help on this acer a315 DA0ZASMB8D0 REV.The problem with this one it came to me as no display, so i open the laptop and find out burnt mosfet near processor area AO6414A so i replaced the mosfet with new one now no lghts i removed the mosfet and check outside it became short, so I checked the pads , i noticed the gate is shorted to ground,anyone can help me on this please, i have attached schematic and pic on the location of the mosfet the mark read is the gate shorted
  • String2016
    • Nov 2015
    • 2234
    • philippines
    Re: Acer a315-25-95kf
    anyone please help already done cleaning but still source and gate are still shorts beeping to ground
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Why not remove the PWM connected to this mosfet and check again??
      • String2016
        • Nov 2015
        • 2234
        • philippines
        @mcplslg123 thanks for the response I remove one side of coil R22 connected to gate and the gate is not beeping to the ground anymore,but source and gate are beeping, any help on this please
        • String2016
          • Nov 2015
          • 2234
          • philippines
          anyone can help please
          • String2016
            • Nov 2015
            • 2234
            • philippines
            any help please
            • mon2
              • Dec 2019
              • 14106
              Hi. If you suspect a mosfet, check the resistance.
              Remove all power. Meter in resistance mode (2k).
              Measure :
              Source (1-2-3) and drain (5-6-7-8)
              Source and gate (4)
              Gate and drain
              Post the measurements. Checking for low resistance values = defective mosfet.
              • String2016
                • Nov 2015
                • 2234
                • philippines
                the burnt mosfet removed measure the shorted gate 0.016k , s= 0.003k and drain ol
                • mon2
                  • Dec 2019
                  • 14106
                  Can you provide details of which mosfet you are referring to in the schematic?
                  These are cpu power rails which are normally low resistance rails.
                  Does your meter have a lower as resistance scale? Use it for these checks. It appears you have 3 ohms to ground which may be too low and be considered a shorted CPU but wait on other replies to this thread.
                  Review this webpage on topic:
                  https://logi.wiki/index.php/Resistance_to_Ground_List
                  • String2016
                    • Nov 2015
                    • 2234
                    • philippines
                    the mosfet above pic burnt is AO6414A connected to R22 COIL my meter is fluke 15b+ i set to manual to kohms
                    • String2016
                      • Nov 2015
                      • 2234
                      • philippines
                      I dont know which side on the schematic because there is no written name on the board and i cannot find a board view on this
                      • String2016
                        • Nov 2015
                        • 2234
                        • philippines
                        anyone please help
                          • 20781
                          Look for the PU2 RT3662ACGQW controller and check which pin the AO6414A gate is connected to.Don`t apply any power to the board.
                          • String2016
                            • Nov 2015
                            • 2234
                            • philippines
                            @smdflea thanks for the response the gate of the burnt mosfet removed A06414A Gate connected to RT3662ACGQW BEL0W
                            PIN4
                            PIN8
                            PIN10
                            PIN22
                            PIN24
                            PIN32
                            PIN36
                            PIN37
                            PIN38
                            ALL of them beeping on shorted gate of ao6414a
                            • String2016
                              • Nov 2015
                              • 2234
                              • philippines
                              i noticed this pc27 both beeping to ground that is connected and beeping on pin 36-38 of RT3662ACGQW
                              • String2016
                                • Nov 2015
                                • 2234
                                • philippines
                                tried removing it but still gate is beeping on the ground
                                • mielta
                                  • Apr 2015
                                  • 368
                                  Hi
                                  Remove PU2 and mesure again
                                  • String2016
                                    • Nov 2015
                                    • 2234
                                    • philippines
                                    @mielta thanks for the response you mean RT3662ACGQW?is there a chance this bad?
                                    • mielta
                                      • Apr 2015
                                      • 368
                                      I Think so
                                      • String2016
                                        • Nov 2015
                                        • 2234
                                        • philippines
                                        UPDATE: remove RT3662ACGQW the short is gone on the gate of 6414A
                                        • ipn00tic
                                          Acer vx5-591G I removed Mosfet and it works without it?! could it cause problem?
                                          by ipn00tic
                                          Hello everybody,
                                          I'm learning alone at home (with you) of course.
                                          I have an Acer VX5-591G laptop that was given to me as scrap where I was training and diagnosing.
                                          The Laptop turns on and starts to boot for a few seconds but before displaying any image it short circuits the main 19V power supply and turns off.
                                          I managed to "repair" the laptop and it turns on and everything works, I even did game tests for the CPU and GPU and everything works but what I did was remove a Mosfet (PQ807) from the VCC_GT power supply.
                                          The VCC_GT power...
                                          03-01-2024, 05:32 AM
                                        • jermac0711
                                          ACER PEW71 LA-5894P CPU_B+ MOSFET NEED HEPL
                                          by jermac0711
                                          Brand : Acer
                                          MOBO: PEW71 LA-5894P
                                          Issue: initially no power. PQ73 mosfet is busted. (AO4466) . Unit has power now but PQ87 is heating up too much (observerd under thermal camera) causing to shut down the system. I tried to remove the removable CPU and the mosfet temperature went normal. I have a replacement CPU from same model but everytime there's a CPU, mosfet PQ87 temperature is rising rapidly.
                                          I hope you guys can shed some light. Thank you so much in advance.
                                          12-17-2024, 08:25 PM
                                          09-06-2024, 05:27 AM
                                        • Kshi
                                          Acer a515-52g no power 19v not passing through first mosfet
                                          by Kshi
                                          I purchased this laptop from fb marketplace
                                          and the previous tech jumped 1st mosfet. maybe it got fix, then time comes by jumpering fried the charging ic?
                                          tried to change mosfet but it does nothing 19v is not passing through 1st mosfet
                                          tried to jumper again, I got 5vlp and 3vlp but 5valw and 3valw is missing
                                          I suspect that the charging ic is bad? If so how do i test if it is bad.
                                          Cant see any short or corrosions on board
                                          schematic and brd view attached below...
                                          07-25-2025, 01:13 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
