Dell 7391 2 in 1 i5 10th gen
  • ss45
    • Jun 2019
    • 119
    • Brazil
    Hi I've got dell with no backlight
    The display is pitch black but if I shine light into the panel, I can see image just fine.
    I have check lcd LED power fuse, ok, voltage is around 8volt.
    I don't know which pin is lcd backlight enable, so if anyone know, please.....
    Since it is 2 in 1 touch , lcd panel is strongly glued to top panel, it's hard to take of and probe the lcd connector directly....
    There is possibility that Lcd inverter MOSFET could be bad, which is a nightmare to replace, since I need to teardown the upper panel and LCD itself...
    Any help appreciated.
  • mon2
    • Dec 2019
    • 14108
    Re: Dell 7391 2 in 1 i5 10th gen
    See attached. Meter in DC volts scale.
    Measure the voltage for pins 1, 19-30. The pins 2-16 can be skipped since you can see the graphics / text on the screen with a flashlight - so the eDP data lines are working fine.
    Post your measurements.
    • ss45
      • Jun 2019
      • 119
      • Brazil
      Thanks will check it this weekend
      By the way forgot to mention.
      When I first booted it, it prompted me to choose which model that PC is, there were 3 options 7791 2 in 1, 7591 in2 in 1, and 7391 2 in 1. I chose the last obviously, since this board is 7391
      Also after that it gave me message that service tag hasn't been programmed.
      After rebooting, service tag displayed in bios and back of bottom panel differs.
      Quite a strange case... Haa anyone had this kind of experience ?
      • ss45
        • Jun 2019
        • 119
        • Brazil
        Here is the measurements
        30-28 8.2v
        27 x
        26 1.5v
        25 3.1v
        24 2.3
        23 0v around 125ohm to ground
        22-19 3.3v
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Pin26 needs to be 3.3V.
          • ss45
            • Jun 2019
            • 119
            • Brazil
            Edit
            Wrong measurement
            Pin 26 is around 3.1v
            So does this mean I need to disassemble the panel ?
            • ss45
              • Jun 2019
              • 119
              • Brazil
              So after opening the panel there was indeed blown fuse inside between 8v.v line and led driver. Luckily no short on the driver. Phew....... Replacing that fuse fixed it
              Thank you all guys
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
                DELL Inspiron 7391 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
                This specification for the DELL Inspiron 7391 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7391 boardview and 7391 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron...
                09-06-2024, 09:10 PM
                09-06-2024, 08:40 PM
                09-06-2024, 04:10 PM
                09-06-2024, 12:36 PM
