A1989 (820-00850-A) Not powering ON, 20V on charger
  • Kloper
    • Feb 2022
    • 10
    • Austria
    its my first post here!
    Just a few things about me so you know who you are dealing with
    I am a complete beginner, never did any board level repairs. I have basic understanding of electronics and I do have a good DMM.
    I have a dead macbook pro, it had some light water spill at a USB C port and since then its not turning on. I may have make things worse by injecting 1.5V but Ill come to that later.
    I do have a boardview and schematic so I will use the names found there to explain the situation.
    When I first opened the laptop, the QB631 was completely corroded. I cleaned it with some IPA and started measuring around that area. Immediately found some shorted caps on PP1V8_SSD0. Assuming I can identify the shorted part by injecting some voltage, I added 1.5V to PIN1 of the C8832 (PP1V8_SSD0).
    That was probably a big mistake, because as soon as I did that, the short was gone. So either I killed something or I have no idea why my short on all the caps there is gone now.
    Current state:
    Plugin the MB into charger, it goes to 5V few sec. later to 20V at 80mA.
    T2 Voltages are all present, I cant find any obvious short. It seems to me, but again, I am a complete beginner, that U9000 has some issues.
    I will attach the schematic of U9000 so maybe somebody can explain to me if that IC should be on or not.
    The 3 coils that this IC is supposed to drive have 0V and that seem to be the power for the SSDs if I understand this right.
    Here is what I measured on the U9000:
    VDD_MAIN: 3.3V
    PGOOD: 3.3V
    All 3 Coils L9020, L9021, L9030: 0V
    ADDR: 3.3V
    V_BUF_1.8V: 0.0012V
    SSD_PMU_RESET_L: 1.8V
    My DMM thinks there are some shorted caps around the CPU area, but they show between 17-40 ohms and I remember reading somewhere that this can be normal for CPU area, doesnt nesserly means they are shorted.
    If you want me to measure something else, just let me know.
    Update:
    Reference to the location I got schematic and boardview: https://www.badcaps.net/forum/showthread.php?t=76497
  • mon2
    • Dec 2019
    • 14262
    Re: A1989 (820-00850-A) Not powering ON, 20V on charger
    Check if all SSD voltages are present.
    Reference:
    https://boards.rossmanngroup.com/thr...ning-on.61479/
    • Kloper
      • Feb 2022
      • 10
      • Austria
      Hi, thanks for the feedback!
      PP2V7_NAND_SSD0 is not present, but I was assuming that U9000 is making the voltages for the SSDs, or I understand that wrong?
      Update:
      I shoot too fast, just realised there are more voltages for the SSDs, how ever non is present.
      PP0V9_SSD0: 0V
      PP1V8_SSD0: 0V
      • mon2
        • Dec 2019
        • 14262
        Voltage of PPBUS_G3H (F7000, pin # 2) ?
        Is PPBUS_G3H steady on the voltage ?
        Is the 20V on the charger static after reaching this rail or power cycling ?
        The 20V level is a good starting sign.
        • Kloper
          • Feb 2022
          • 10
          • Austria
          PPBUS_G3H is present with 12.5V and stabel.
          My USBPowerMeter looks stable.
          I found 1 pin that shows 20V on the board and it is stabel, how ever, I found a testPin that is jumping around, fluctuating alot cant even get a stabel reading.. its between 1-2 or maybe 0-2V on the TestPin TP(1)SAVE_XB_CC1_Z
          • Kloper
            • Feb 2022
            • 10
            • Austria
            Any idea what else I can check or what could be the problem?
            Actually, if U9000 should generate this voltages as soon as the laptop gets power, then thats clearly the issue, or not?
            • mon2
              • Dec 2019
              • 14262
              Confirm the voltage of SSD0_VR_P2V7_EN (R9082, pin # 1 or #2).
              U9000 is creating an enable signal pin that is to travel to U9080, ball # E4 (through the 0 ohm resistor @ R9082).
              Yes, U9000 appears to be the PMIC for the SSD. Perhaps it is corroded underneath the device.
              Remove all power.
              Consider to apply flux onto the top side / perimeter of this device. Apply polymide tape (kapton) on surrounding parts that you do not wish to disturb. You can also use aluminum foil to protect such tiny parts. It is not fun to fix nor find tiny parts that have flown away.
              Then with high heat but low air pressure, allow for the flux to melt and do its job. Proceed to move the hot air tool over the top surface of this device in circles. If required, increase the hot air pressure, slowly.
              Eventually the balls will melt and then gently nudge the chip at the corners.
              The chip should move away with the gentle nudge and then will bounce back into position of the wlcsp (BGA) pcb pads. This is what Louis calls - 'make it dance'. The process works very well. Do this 2-3 times and the balls should self correct underneath the device and create a fresh bond.
              While you are reflowing parts, consider to also reflow U9080 with the same technique.
              Be patient when you do this process, never push hard with the tweezers to nudge the chip as this can tear off the PCB pads and then it is game over. The hot air tool with enough heat + flux + air pressure will melt the underneath balls. We do not want to smear the solder balls nor flatten them - just correct the solder joints with the 'dance' of the chip. You can find assorted youtube videos on this topic from Louis Rossmann and Alex (NorthRidge Repair).
              Allow the part & board to cool for 5-10 mins at least.
              Then test again. Post your results.
              This part may need to be replaced but the SSD needs to be powered and that power is from U9000 as you have posted from the start of this thread.
              • Kloper
                • Feb 2022
                • 10
                • Austria
                R9082 has 0V
                I will try to reflow U9000 today... never did that before, so its gonna be interesting
                U9080 I think ill skip since the water never got there. Only a few parts on the edge of board ware effected, atleast visible.
                Ill update you after I did the reflow.
                Thanks for your help and time!!
                • Kloper
                  • Feb 2022
                  • 10
                  • Austria
                  Reflow didnt work really... I was just too afread to melt the connectors next to it. I did heat the IC for while and components around it started turning shiny but the IC just didnt want to move so I stoped before I melt everything. I dont have microscope to really see well what I am doing there. I will see if I can get somebody who has more experience with this and let him try it, or replace the IC... I feel like Ill just make things worse.
                  Thanks for you help tho!!! Really appreciate it!!!
                  • motormayhem
                    Lenovo T460 Only Charges on One Charger
                    by motormayhem
                    Laptop Question
                    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                    05-12-2023, 01:46 PM
                  • ErinV
                    MacBook Pro A1989 820-00850-A not powering on
                    by ErinV
                    Hey everyone!
                    I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                    I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                    The diode voltages around all 4 CD3215's seem fine.
                    For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                    09-30-2024, 10:21 PM
                  • serious_electron
                    Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                    by serious_electron
                    Hello Everyone!
                    I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                    06-28-2025, 02:57 PM
                    NVDC charger configuration...
                    11-05-2024, 03:28 PM
                  • flat-earther
                    how to prevent a connected charger from draining battery when not charging?
                    by flat-earther
                    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                    So the battery is backfeeding the charger and being drained.
                    How can I prevent...
                    08-07-2025, 01:04 PM
