hello everyone, I have a problem with my macbookpro 2017 820-00928, it's stuck at 20v 0.20ma, the indication of heat on the U8295 ic on the PP3V_S0_LEFT line, I've removed the ic and I shoot the voltage but there is no indication of heat in other areas, these are all rails except Vcore cpu..what should I explore next,,thanks
					a1707 820-00928
 Re: a1707 820-00928
 Hi. Try to avoid voltage injection till more is known about the logic board. Otherwise, this can cause permanent damage to the circuit board.
 With U8295 removed, place your meter in resistance mode (2k scale). Remove all power.
 Check the resistance to ground of pins 3 and 5 of U8295 pads. Something is causing this part to heat up and could be an excessive load on the rail.
 Post the readings.
			Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
 The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
 Securing a good thermal interface between...-
							Channel: Common Parts Library - Datasheets
 10-07-2024, 04:35 AM
			by CG_DionysosHello,
 I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:- Model: A1707
- 15-inch, Mid 2017
- 3.1 GHz Core i7
- 16 GB RAM
- Radeon Pro 560
- 1 TB SSD
- Board number: 820-00928-A
 Thanks in advance!
 Greetings from Germany...-
							Channel: Schematic Requests ONLY!
 09-16-2025, 06:43 AM
			by obelix24I got two Macbook's Pro 15" A1707 both fully working except no image on internal LCD.
 I've checked and it looks like it's problem with U9850 (on both pin 1 on screen connector is 0.007 or 0.050 in diode mode)
 My question is if this IC can be ordered from Aliexpress (will it work) ?? or it needs to be taken directly from donor (a1707, a1990, a2141) ?
 Is this IC interchangeable (on my board i have 6142E and i found that there can be also HD3SS212) are this chips same ? ? Is it possible to find this IC on some other Macbook 13" (air, pro) ?? i have...04-25-2025, 07:55 AM
			by harpdetecting heat with IR LED receiver
 I have some dark IR led, and want to know if it is be situable to detect pure heat (not visable glow ir radiation) in well lighted desk?
 So, if I put hand over it in near distance like few centimeters, that detect rising heat, not covering it from light.
 Something like termal camera, but in one spot, any simple circuit?...
			by ludovikHello everyone,
 i was reballing the power manger of a moto g84, after applying heat i tried to power on and it wouldn’t.
 i injected 1.5v to some capacitor that seem in short because both side beep if tested.
 when i inject i feel the cpu burning;
 since the cpu is exactly on the other side of the board, is that possible that the heat from the reballing damaged the cpu? do you know where i can find schematics or what can i do?
 i know this is not enough to explain the situation so if you need any other info ask me please!
 Thank you very much in advance11-08-2024, 02:13 PM
- Loading...
