Ideapad 500 LA-C851P not power on.
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Hello friends.
    got this motherboard la-c851p not power on.
    Amp taken 0.000..NO schematics or brd are avalaible.
    I use La-C771p as mention from another thread.
    Taken this voltage :
    First mosfet =n-channel = D=19V/S=0v/G=0V
    Second mosfet =n-channel = S=0v/D2.5V
    So i take BQ24780 voltages :
    pin 28 = 19V
    pin 6 = 2,7V
    pin 24 = 6V
    pin 5= 0V must be 3V
    pin 3 = 0V must be 19V
    No short to gnd , i make a little trick to verify, desoldered second mosfet , tested ok, before soldered i take voltage again , without second mosfet so ..
    First mosfet =n-channel = D=19V/S=19v/G=25V
    ACOK = 3V
    CMRSRC = 19V
    So my charger ic and mosfets are ok...what i am missing !!!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Ideapad 500 LA-C851P not power on.
    Very likely a shorted discharge mosfet. Check voltage on charging coil. Is it showing 19V?
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      Thank you mcplslg123
      No , i find 2,6V a pl301..Same volt at sensor resister and drain of second mosfet.
      i test the 3 mosfet of battery charge pq302/305/306 out of board and they are ok .
      What to check else !!
      • Mayank tater
        • Jan 2022
        • 6
        • India
        If after remove second mosfet you get 25v on 1st mosfet get so change 2nd mosfet its solved
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          Thank you maynak , second mosfet was tested out of barder and his is at good condition , but try your advice and still same issue.
          When i remove second mosfet and inject 20v at Drain place i got 0,O10 amp consumption, try to power on with button it reach 0,048 amp than back to 0,010 amp.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Replace the charger IC even if everything is ok after removing 2nd mosfet. make sure to check suffix as BQ24780 and 24780S are not compatible. If condition remains unchanged, try a jumper to cmsrc pin of bq24780 and the other end to Drain of 1st mosfet(This will bypass the current sensing). Update about result. Sometimes replacing the caps connected to dc-in fets solve this mystry(specially on acer). BQ24780 often has this problem and there is no perfect one solution. the solution varies from board to board.
            PS: I assume you have checked and confirm there is no shorting after the 1st dc-in fet.
            • lapfix
              • Mar 2020
              • 2764
              • my workshop
              I assume you have checked and confirm there is no shorting after the 1st dc-in fet.....Yes of course , no shorting at all coil , tested as usuall twice with diode mode and ohm mode .
              Update : before do what you ask for..inject 3V at PL402 : 3valws i find a big consumption 0.900 amp ,whith help of flirone i got a hot place at UA1 ,lan circuit i desoldered still got consumption of 0,130 amp , i find U13: the 3 and 5VS getting hot too , desoldered still got consumption....than i desoldered PU401 : the 3 valws...the charger circuit with his 2 mosfets works good and i find 19V at sensr resistor!
              I try to test 3VL for short or remplace the SYX196BQNC circuit .
              In other thread you don t recommand SY8208BQNC and another friend post that SY8206BQNC is ok...So i will try and give feedback
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Good progress friend. however, you should've checked shorting at 3V earlier before troubleshooting charger IC.
                • ebyte64
                  Lenovo IdeaPad 330 laptop mosfet issue
                  by ebyte64
                  Good day everyone.
                  I have been scratching my head with a Lenovo laptop I got in today.
                  The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
                  Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
                  Would anyone...
                  06-27-2023, 10:19 AM
                  Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                  This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-07-2024, 05:20 AM
                  Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                  This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                  This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                  09-07-2024, 05:00 AM
