Please Help, Acer Aspire 3 not charging!
  • roxboy1984
    • Jan 2022
    • 177
    • South Africa
    HI, I wonder if anyone can please help me. Im very new to component repairs, but i repair computers for a living, just not component level as yet.
    Basically i have an Acer Aspire 3 A315-54k which had a glass of water spilled on it and needless to say it no longer worked after that. i ad my guys who do component repairs repair the charging/power circuit and all is well again except im having a very strange issue whereby the battery will not charge unless its completely depleted to 0% and then it will charge when i plug it in. however if i remove the charger at any point during this process and reconnect it, i have to then wait for the battery to deplete completely again in order to try and charge it.
    Once the machine is charged to 100% if i use the machine while its plugged in the battery percentage will just slowly drain until once again it reaches depletion.
    What im trying to establish is whether the issue resides in the battery being damaged in the spill or something else on the motherboard that is faulty. ive eliminated chargers etc.
    i just dont want to purchase a new battery if thats not the issue.
    Thanks in advance for any help that can be offered.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Please Help, Acer Aspire 3 not charging!
    So you mean battery percentage is slowly going down even when its plugged in?? If so most likely some mosfet in charging/discharging and/or dc-in section is leaky. So do check all these mosfets
    Source(Pin1-2-3) to Drain(Pin 5-6-7-8)
    Source to gate(Pin4)
    Gate to Drain
    The measurements should be without power adapter and battery and meter should be set in resistance(Ohms) mode.
    • reformatt
      • Feb 2020
      • 1412
      Not sure about this model, but most Acers have a switch under the service door for the battery to enable it. So check that first.
      • roxboy1984
        • Jan 2022
        • 177
        • South Africa
        Gate to Drain
        Thanks for the reply. so yes the percentage is slowly going down even when plugged in. but i can get it to charge absolutely perfect once the battery goes down to 0%. The guys who did the repair changed all the MOSFETS, Caps etc in the charging circuit even changed the actual charging chip and same issue.
        Is it likely that the battery could be the cause? im not familiar with how the battery internal circuitry works.
        • roxboy1984
          • Jan 2022
          • 177
          • South Africa
          If this switch was an issue would it not cause the battery not to work at all?
          • reformatt
            • Feb 2020
            • 1412
            If I recall, the battery works, just doesn't charge. Caught me out once.
            • roxboy1984
              • Jan 2022
              • 177
              • South Africa
              Thanks, What i meant was the battery does actually charge it just has to be completely drained before it does. So i would assume that rules out the switch?
              • reformatt
                • Feb 2020
                • 1412
                Probably. What motherboard is fitted to this machine? LA-H792P? If so, and it's using the BQ24781 charging IC, then review the BQ24780S datasheeet on pg 17 for charging conditions. (BQ24781 datasheet isn't available but it's primarily the same logic as BQ24780S).
                Also review the first 2 input FET's (this design has 3 actually), PQB1, PQB3 and PQB4. The capacitors and resistors around these FET's are critical insofar as timing, and the BQ chip will disable charging if the timing is not correct.
                https://www.ti.com/lit/gpn/bq24780s
                • gurj1979
                  • 186
                  Have a look at PQZ1 MOSFET. In my case this was shorting out the entire main 19v rail and prevented charging or anything. I swapped this out with another MOSFET with 30v N Channel 58A, and I got power restored.
                  • abrahim110
                    [Help Needed] Acer Aspire 5 A517-52G โ€“ Removed Onboard RAM, Now Working But Battery Not Charging
                    by abrahim110
                    ๐Ÿงต [Help] Acer Aspire 5 A517-52G โ€“ Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
                    I have an Acer Aspire 5 A517-52G-53NB laptop.
                    The onboard (soldered) RAM was faulty, so I physically removed the chip.
                    I also successfully modified the BIOS using the SPD Removal Tool โ€“ the laptop now boots fine and works with an 8โ€ฏGB DDR4 SO-DIMM installed.
                    โœ… System status:
                    • BIOS mod is done (SPD removed)
                    • Laptop boots to Windows normally
                    • RAM is detected and stable
                    โŒ Problem:
                    The battery is not charging:
                    • Power adapter
                    Yesterday, 06:15 AM
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                    ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                    This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-12-2024, 03:28 PM
                    ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                    This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-12-2024, 02:30 PM
                    ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                    This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
