HP 650 G2 Troubleshooting Help
  • ionut68
    • Sep 2020
    • 8
    • Romania
    Hi
    I'm asking for help with the CIRCUS-6050A2723701-MB-A02 motherboard that I can't turn on.
    I have typed into memory all the bios posted on this forum, with all pretty much the same result: Turns on the fingers, POWER, AUDIO on/off, and WRILES LED, and after 10-15 seconds the fan starts up with increasing speed.
    All voltage sources are OK except for two that don't draw any voltage:
    U66010 and U66310 (SIC631) = 0V I measured with ohmmeter against ground the outputs after coil L66010 and L66310 = 5,311Ohm
    I measured the voltages on pins U66010 and U66310:
    Voltages with power OFF button
    Pin 1=0V
    Pin 2=2V
    Pin 3=5.2V
    Pin 5=4.9V
    Pin 7=0V
    Pin 8,.....11=19,7V
    Pin 16,....23=0V
    Pin 29=5,2V
    Voltages with power button ON
    Pin 1=2,58V
    Pin 2=0V
    Pin 3=5,2V
    Pin 5=4,9V
    Pin 7=0V
    Pin 8,.....11=19,7V
    Pin 16,....23=0V
    Pin 29=5,2V
    Translated with www.DeepL.com/Translator (free version)
  • ionut68
    • Sep 2020
    • 8
    • Romania
    Re: HP 650 G2 Troubleshooting Help
    Can anyone tell me what the voltage should be on those two sources?
    What is the value of the output resistance to ground?
    • keczuk
      • Dec 2019
      • 83
      • WWW
      did u solve this problem ? i have same issue ?
      • Sephir0th
        • Oct 2020
        • 1262
        In these cases it is often a communications issue between the VRM Controller and the CPU, which usually means the CPU is bad. Measure Power Inputs, Enables, PGood, VRHOT# and ALERT# to have a basic overview
        FairRepair on YouTube
        • Capacitorial
          Powersupply has all the voltages - Monitor still no power
          by Capacitorial
          Hello guys,
          I have a Philips 240B7QPJEB. The monitor seems completely dead.
          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
          The weird thing is, that the Power LED is powered over the TCON board.
          On The TCON...
          12-28-2024, 02:12 PM
          Acer Swift SF314-52-549V Notebook 3 Specification for Upgrade or Repair
          This specification for the Acer Swift SF314-52-549V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-52-549V boardview and SF314-52-549V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 06:02 AM
        • blues_spirit
          practical courses for troubleshooting pc motherboards
          by blues_spirit
          Hello from France,
          mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
          Do you think this is feasible for me? I...
          12-18-2022, 12:56 PM
        • Awsmessymail
          Vizio E701i-A3 backlight only and now no backlight
          by Awsmessymail
          Hello all,
          I’ve tried to repair TVs in the past with some luck. Toms repair manuals got taken down and now thats a bit harder.
          I picked this TV up hoping for a quick fix. When the TV would power on, only the backlights would come on. The owner told me they heard loud screeching before it shut off. This alone makes me want to think the main board has an issue.
          As I researched, I found the TCON/driver boards were an issue on this unit. I went in troubleshooting the TCON but found good voltages on the TCON. I followed shop jimmys guide to test the transistors and they seem okay....
          02-13-2024, 11:04 PM
        • gjgib
          Help reading schematic voltages input/output
          by gjgib
          Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
          I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
          I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
          I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
          05-06-2024, 08:11 PM
