Dell Latitude E5450 doesn't detect any HDD
  • pingaroon
    • Nov 2019
    • 121
    • uk
    Hi, I have a problem where the board refuses to see ANY Hdd via the Hdd adapter cable (which is 100% good on other boards). The board boots USB sticks no problem, but when a (known-good) HDD is connected, the Dell logo stays up for a long time and it eventually baulks with "no boot devices found". No combination of bios settings makes any difference (it has the latest version)
    The schematic shows pin 13 of JSATA1 connects to HDD_DET (presumably that is HDD detect?) which connects to pin U1 of @UC1E. My experience of interpreting schematics is limited - can someone confirm what @UC1E is?? I can't find anything like that on the board itself.
    Any advice on how to proceed would be welcomed.
    Thanks chaps
  • reformatt
    • Feb 2020
    • 1488
    Re: Dell Latitude E5450 doesn't detect any HDD
    First 7 pins of JSATA1 are data, the others are for power. HDD_DET# is an output from the drive and should be ground. Check for power rails to the connector and see if the drive spins up. If the drive doesn't go ready, it won't be detected by the host.
    • pingaroon
      • Nov 2019
      • 121
      • uk
      Hi, I should have mentioned that all drives spin up ok, so it looks like a data problem. Where to go next? Thanks
      • reformatt
        • Feb 2020
        • 1488
        First, is the drive detected by the BIOS and just won't boot from it? Or is the drive not detected at all?
        • pingaroon
          • Nov 2019
          • 121
          • uk
          Hi, no the drive is not seen by the bios. Same with any drive - no matter how they boot (UEFI/Legacy boot).
          They spin up, but are not detected. I've eliminated the HDD connector and the drive(s) as all work fine on other boards.
          • reformatt
            • Feb 2020
            • 1488
            UEFI/Legacy is irrelevant if the drive isn't seen in BIOS. If the supplies to the connector measure fine (+3.3V/+5V etc), then I'd be paying attention to the TX/RX data pairs. These connect via capacitors CN17~19 to UN2 (SATA Repeater). Buzz out the connections from the connector to the caps, from the caps to UN2. Also check that UN2 has power etc. Then use a scope to see what data activity you have. My assumption is that you will only see data activity initially from the host on one data pair on boot up, which is then expecting a response from the drive from the other data pair.
            • pingaroon
              • Nov 2019
              • 121
              • uk
              ...I'd be paying attention to the TX/RX data pairs. These connect via capacitors CN17~19 to UN2 (SATA Repeater). Buzz out the connections from the connector to the caps, from the caps to UN2. Also check that UN2 has power etc. Then use a scope to see what data activity you have. My assumption is that you will only see data activity initially from the host on one data pair on boot up, which is then expecting a response from the drive from the other data pair.
              That's extremely helpful, thanks - I'll check these and report back.
              • pingaroon
                • Nov 2019
                • 121
                • uk
                ok, I found the 4 caps which connect to the TX/RX lines - all beep with the corresponding pins on JSATA1 and all the caps are good.
                The chip at UN2 has correct voltage and isn't short (only 1 ground pin). I even swapped it out with the same chip from an old board, but it's still refusing to detect any drive. I don't have an oscilloscope to see what's going on with the data lines, but everything on the face of it appears to be normal
                • khaahk
                  • Dec 2013
                  • 810
                  • Estonia
                  Any evidence of bios being tampered (signs that the chip has been removed)? Intel ME region has a part called flex io configuration and the ports can be reconfigured in there.
                  • pingaroon
                    • Nov 2019
                    • 121
                    • uk
                    Yes, I was starting to think it could be ME-related. I'll reconfigure it with fitc and see if comes alive again. I know poorly configured ME sections can stop network/SD cards etc from being detected, so will report back, thanks.
                    • pingaroon
                      • Nov 2019
                      • 121
                      • uk
                      Well, it's not the bios, sadly. Swapped it out with a known good, cleaned ME version but still no dice. Was trying to find the flex io section in fitc - can you point me to where it is?
                      I guess the next stage will get to measure the data i/o with an oscilloscope - this is something I have not done before, not owning a scope. Will do some research.
                      Thanks.
                      • khaahk
                        • Dec 2013
                        • 810
                        • Estonia
                        Seems that in fitc 10 the sata configuration was under PCH strap#14, the clean ME configuration is probably right. The flex io came in fitc 11. I have had the same problem with LA-901P, did not solve it then. (changed UN2 also).
                        • pingaroon
                          • Nov 2019
                          • 121
                          • uk
                          Useful info, thanks.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Try removing The UN2 sata repeater and then jumper between PIN 1-15/2-14/4-12 & 5-11
                            .See if the HDD is detected.
                            • indyga
                              • Jul 2020
                              • 42
                              • Greece
                              Greetings ro all,
                              Does anyone found a solution. I have the same problem and everything seems alright
                                DELL Latitude E5450 Notebook 5000 Specification for Upgrade or Repair
                                This specification for the DELL Latitude E5450 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E5450 boardview and E5450 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                09-06-2024, 08:40 PM
