Macbook Pro 2012 15" possible short on 3v3_S0
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello guys,
    I have faulty 15" Macbook Pro 2012 with 820-3330-B motherboard with the following symptoms:
    - when turned ON, there is a short increase in current to up to 0.8A (power supply unit display)and then back to zero.
    - during this short time, one FAN try to spin (better to say vibrate).
    I have done measurements on power rails and found that PP3v3_S0 is most likely shorted to ground. Multimeter readings are the following:
    - 0.017 in diode mode (positive leas is on ground)
    - 16 ohm t ground in resistance mode.
    I'm pretty sure this is the culprit, but there are so many components connected to this power rail, and I don't have a thermal cam, so I wonder if it would be possible to find a faulty component by voltage injection
    I have a lab PSU 0-30V, 0-5A. What would you recommend me to do? Where is the right spot to try to inject the voltage?
    Thank you.
    P.S: SMC is running (PPBus_G3H is 12.56 V), and there is PP3V42_G3H, since there is a green light on the charger.
  • Askic
    • Sep 2018
    • 187
    • BIH
    Re: Macbook Pro 2012 15" possible short on 3v3_S0
    I'd like to provide a bit more information.
    All 5 big coils L(7510,7520,7530, 7550, 7560) have 1.3 ohm to ground or more precise 1 ohm to ground (resistance of multimeter leads is about 0.3 ohm).
    Mosfet Q7810: 3.3V S3: PP3V3_S3_FET has 0.36 V to ground (in diode mode)
    Mosfet Q7830: PP3V3_S0_FET pin 5 has 0.016V to ground, while PP3V3_S0_P3V3S0FET pin 3 has 0.138 V to ground or about 140 ohm to ground. This pin is actually PP3V3_S5.
    • Askic
      • Sep 2018
      • 187
      • BIH
      Hello, just want to update and provide more information in order someone to be able to help or give some useful advice.
      When injecting 3V into 3v3_S0 line, I noticed that U9220 (DP AUX, DDC, & HPD muxing to IG/EG) is getting hot.
      After removing this chip from the board, resistance od 3v3_S0 line was restored to 1.9 kohm, which is to be expected (it was 16 ohm with U9220 on the board).
      I think that U9220 is not a critical component to start the MBP, so I tried to start without U9220, but no luck.
      I have noticed that PM_SLP_S4_L is missing, so this is the main problem now. As far as I can conclude from the schematics, PM_SLP_S4_L is an output signal from U1800 chip. Is there any more I can do now?
      • piernov
        • Jan 2016
        • 4435
        • France
        https://logi.wiki/index.php/User:Pie....2C_what_do.3F
        • Askic
          • Sep 2018
          • 187
          • BIH
          Hello Piernov,
          first of all, I don't have original 85 W charger for this laptop. I use PSU with Magsafe1 cable (L style connector). However, I also have a good working battery. I tested this with battery.
          I do have PM_SUS_EN and SMC_BATLOW_L when battery is connected, so I think this issue is not due to non original charger.
          I have also noticed that when battery is connected and I turn ON my PSU (connected to the board), there is a short pulse on PM_SLP_S4_L (about 1 sec 3.2V) and then zero.
          • playit
            450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
            by playit
            hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
            09-02-2023, 02:43 AM
          • sdogs
            macbook pro M1 a2338 no video on internal display PP3V3_S2 short
            by sdogs
            Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
            First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
            I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
            06-27-2025, 01:58 PM
          • sdogs
            by sdogs
            06-27-2025, 11:26 AM
          • Rezendes
            Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
            by Rezendes
            Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
            I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
            The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
            05-10-2024, 02:18 PM
          • korben_dallas
            Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
            by korben_dallas
            Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
            I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
            I'm new to soldering but the only feasible way to fix this issue is to do something myself.
            MY QUESTION:
            I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
            02-14-2024, 12:23 AM
