Lenovo L13 (USB-C VIN ONLY 5V NOT 20V)
  • medinfo
    • May 2016
    • 331
    • Morocco
    Lenovo L13
    MB : LAR-1 MB 18834-1M
    the computer starts normal with the battery, but does not start with the type-c charger, the usb type-c port only gives 5v not 20v .
    [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/showthread.php?t=125078
  • mon2
    • Dec 2019
    • 14657
    Re: Lenovo L13 (USB-C VIN ONLY 5V NOT 20V)
    Do you have a USB Type C meter ?
    Use it in series with the external adapter & this computer to confirm the current draw.
    It is possible that the CC1 & CC2 lines are damaged from a hot adapter removal and cross shorts across the Type C contacts. Industry claims this very serious fault has been fixed with the wimpy BMC communication lines being tolerant to > 20V hits but do not know about this TI controller.
    Start with removing all power.
    Place your meter in diode mode.
    Red meter (yes, red) lead on GROUND. Black meter lead on CC1 line. Diode reading?
    Then repeat for CC2 line. Trying to determine if either one of these lines is damaged.
    • medinfo
      • May 2016
      • 331
      • Morocco
      meter in diode mode
      Red meter on GROUND and Black meter on CC1 USB2
      Charger plugged in : Diode in meter = 680
      Charger not plugged : Diode in meter = 612
      • mon2
        • Dec 2019
        • 14657
        Do not power up when testing with the DIODE mode.
        Leave the charger removed.
        Repeat the same test for CC2 line. Both, the CC1 and CC2 lines are used by the logic board & external power adapter to select the power delivery contract. The 5V contract is a power on default.
        • medinfo
          • May 2016
          • 331
          • Morocco
          =470 in both CC1, CC2 !
          • mon2
            • Dec 2019
            • 14657
            Post the voltage for each of the pull-up resistors in the attachment.
            Interested in the voltage on each of the '_I2C_' lines.
            Update:
            Also confirm the voltages on the Power Delivery Flash device. See attachment.
            • mon2
              • Dec 2019
              • 14657
              Can you also confirm if the CC1 & CC2 measurements were taken at the USB connector ?
              That is:
              USB2_CC1_CON
              USB2_CC2_CON
              • medinfo
                • May 2016
                • 331
                • Morocco
                sorry for the late reply and thank you for the interest in my problem.
                this is the all mesurements .
                • mon2
                  • Dec 2019
                  • 14657
                  Can you confirm that the type c charger is able to select 20v ?
                  Do you have any macbook units with type C?
                  Just to confirm that the adapter is not defective.
                  • mon2
                    • Dec 2019
                    • 14657
                    For this design, U7301 is the decision maker for the power delivery contracts. This is an intelligent controller that communicates with the outside power adapter (type C) to request a catalog of power delivery contracts (voltage & current pairs). Then this component @ U7301 selects the best choice for the logic board (20v) to move forward.
                    Respectively, the communication is over the CC1 and CC2 lines.
                    You can try to flip the type C connector upside down and test again. Suggest to always, remove power on the type C adapter, seat the connector and then plug into the wall. This way, there is no 'hot' circuit on the adapters. Safer this way.
                    Do confirm that the type C contacts are CLEAN with alcohol & Q-tips. Have seen many burnt or liquid damaged contacts in our shop.
                    Next, between U7301 & the physical connector on the laptop is an ESD protection device @ U7503. It is very possible that this device is damaged and blocking the communication between the Type C controller (U7301) & the outside world (type C power adapter).
                    Check in diode mode, with all power removed, the readings of pins 11 & 12 on U7503.
                    Also, pins 4, 5, 6 and 7.
                    Check for any physical damage - clean up the solder contacts of any debris.
                    At this time, not sure if U7301 has factory firmware - most likely it will. It is a state machine device and will need some form of code to decide when to select which contract. TI should offer more details. Believe this is a public offering for this controller. If needed, we can post a request from the TI engineers in their user forum for more details about this laptop.
                    A very good tool here would be to have a USB Type C bus analyzer to study if there is any communication between the laptop & power adapter.
                    • Rotter
                      • Mar 2007
                      • 22
                      I just got this same notebook with the same problem on my workbench.
                      Only got 5V on the USB-C Connector.
                      there is no activity on the CC1 and CC2 pins.
                      replaced U7503 (CC Protection IC) -> no change
                      3D3V_LDO_PD is present.
                      3D3V_S5 is at 0V, which is guess could be normal in this state.
                      i see some periodic activity on the CS# bin of BIOS2 (EC7301) which i guess is the Firmware for the TPS65988DH (U7301).
                      I would like to reflash its rom, but could not find a dump anywhere, tried to find it inside the official bios update file from lenovo and inside the dump offered here.
                      Could somone please make a dump of this chip?
                      i will attach the one i read from my defective board,
                      Best regards.
                      Last edited by SMDFlea; 10-24-2023, 08:15 AM. Reason: bios removed,this is not the bios requests section
                      • REpairAT
                        • Nov 2020
                        • 143
                        • Austria
                        Best regards.
                        had the same notebook for repair with another issue, dumped the chip. I can't guarantee that this dump is fully functional, because the computer turned always off after few seconds, but voltage was always present.
                        Give it a try and let me know.
                        https://www.badcaps.net/forum/attach...5&d=1648656194
                        BR, Ray
                        • Naeem4rush
                          • Dec 2021
                          • 43
                          • Pakistan
                          Hi
                          i am in same problem but cc1 1.35v when i turn usb-c cable than cc2 is 1.35v
                          if any body know the problem ?
                          • Naeem4rush
                            • Dec 2021
                            • 43
                            • Pakistan
                            REpairAT
                            you save the day your dump worked for me .
                            • Jasinka
                              • Oct 2023
                              • Lithuania
                              i have same problem with L13 just 2th generation. Input with usb c is just 4.97v.
                              If i will use this custom bios it will help or i should change some parts? Thanks.
                              Found smth on youtube its says can be shorted with chipset...
                              Charging with second port - everything is fine.
                              Thanks for help in advance. i am noob here.
                              • bobrino
                                • Aug 2015
                                • 7
                                • Ukraine
                                in my case, the pd type-c controller firmware helped
                                • nikolayu
                                  Lenovo ThinkPad X1 Nano Gen 1 not charging on 1 USBC
                                  by nikolayu
                                  I have Lenovo ThinkPad X1 Nano Gen 1 which is not charging on 1 usbc port (the one that has mark for charging).
                                  When i connect usb it switchs to 20v but no current draw (only 0.02a) and orang light is on. In windows it shows that is charging but percentage is dropping.
                                  Other usbc is charging fine,
                                  I installed lates bios and firmwares for thunderbolt and battery.
                                  Could be faulty JHL8040R controller?
                                  08-31-2024, 11:08 AM
                                • MrSparkle91
                                  Help with a blown Diode (Lenovo 15ith6h)
                                  by MrSparkle91
                                  I have recently gone to clean my laptop and noticed a bad Diode that's gone poof. I have also located it on the schematic also.
                                  Whilst I'm good at repairing stuff in general, I would like some kind insight into what I'm working with here and the Diode I would need.
                                  I have checked the whole laptop and suffer no issues usability wise, which is why I was shocked to find this, but am I right in thinking this is power voltage related?
                                  Thanks in advance....
                                  08-01-2025, 10:30 AM
                                  Lenovo 3000 Series Schematic
                                  Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                  3000 C100 laptop with Braille keyboard
                                  Lenovo 3000 C
                                  C100, C200 - 15-inch XGA screen
                                  Lenovo 3000 N
                                  N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                  N500 - 15.4 inch screen.
                                  Lenovo 3000 V
                                  V100, V200 - 12.1-inch WXGA models
                                  Lenovo 3000 G
                                  G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                  10-04-2024, 06:05 AM
                                  Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                  This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                  09-06-2024, 06:40 AM
                                  This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                  09-06-2024, 06:06 AM
