Re: MacBook Pro A1990 doest turn on
Confirm that U6940 is being powered. Check the voltage on PP3V3_G3H_RTC_X. - The Voltage is 3.36 v
While there, check the voltage of pins 3 & 4 of U6940. -
the pin voltage is also 3.36V
PMU_ONOFF_L : 3.36v
PMU_RSLOC_RST_L: 3.36v
Check that this value matches BOTH sides of R4911. both sides are 3.36v
The resistance to ground of CHGR_RST_IN_R is too low.
Remove the resistor @ R6940 and then check the resistance again for CHGR_RST_IN_R. Is it still very low ?
If yes, remove the resistor @ R6941 and then check CHGR_RST_IN_R resistance to ground again.
I think that i did a mistake and i measured the resistance when the power was on.
the resistance reading on R6940 and R6941 is 326Kohm
PMU_ONOFF_L : 3.36v
