dell latitude 7490 la-f322p short on +rtc_cell
  • kjchatman
    • Dec 2012
    • 198
    • united states
    this board doesn't power up at all. there is a 1 ohm resistance to ground on +rtc_cell. 1v was sent through the rail and the sio (mec5105) got warm. The sio was iremoved and the short was gone. It was replace with a new sio and the short is back
  • mon2
    • Dec 2019
    • 13994
    Re: dell latitude 7490 la-f322p short on +rtc_cell
    See attached.
    Locate the PC3 cap that will be mated to the common cathode of the dual diode @ PD3.
    Remove all power. Meter in resistance mode.
    Red meter probe on the location in the attachment.
    Black meter probe to ground.
    What is the resistance to ground ? Is it 1 ohm ? If yes, remove capacitor PC3 off the logic board and measure again.
    Next check the coincell +v location in the next attachment.
    What is the resistance reading to ground for this junction ?
    Is it 1 ohm ? If yes, remove the PC2 capacitor off the logic board and measure again.
    • kjchatman
      • Dec 2012
      • 198
      • united states
      pc3/pd3 with the super iO removed reads open loop. I put the super IO back on and it reads 1 ohm. the resistance of the coincell +v is open loop regardless of the super IO being attached or not. why would a brand new sio cause the +rtc_cell to short
      • mon2
        • Dec 2019
        • 13994
        How confident are you of the soldering of the new super I/o chip? Is it a bga package?
        Consider to reflow it with lots of flux and heat to make it 'dance' with a gentle nudge of the tweezers at the edges. This should allow for the bga balls to properly align without adjoining shorts.
        Is the replacement ic a known good part? Is it the same part? From a reliable vendor or donor board?
        Check the nearby balls of this ic. Are there surrounding ground pins near the coincell pin under the super io chip? Solder shorts may be causing this fault.
        • kjchatman
          • Dec 2012
          • 198
          • united states
          ordered it from a vendor in germany off of ebay an received it today. it's the same part as the original (mec5105). it was reflowed with genuine amtec flux and the Ic was perfectly centered within the squared outline
          • mon2
            • Dec 2019
            • 13994
            Aligned correctly to pin #1 orientation?
            • kjchatman
              • Dec 2012
              • 198
              • united states
              yes it is aligned correctly
              • kjchatman
                • Dec 2012
                • 198
                • united states
                could it be the dual diode? the super IO seems to have low resistance to ground even on a working board
                • mon2
                  • Dec 2019
                  • 13994
                  Remove the dual diode and test it out of circuit.
                  In diode mode, should conduct in one direction and block in the other. Test each internal diode.
                    DELL Latitude 7490 Notebook 7000 Specification for Upgrade or Repair
                    This specification for the DELL Latitude 7490 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7490 boardview and 7490 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7490...
                    09-06-2024, 12:36 PM
                    09-06-2024, 12:13 PM
                    DELL Latitude 7490 Notebook Specification for Upgrade or Repair
