Dell Inspiron 15 33308 random shutdown
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hello i got this laptop that have problem with random shuting down. It can work for several hours and then it turn itself down and sometimes work only few minutes. Laptop came without battery.
    Things that i try:
    Clean it and change thermal paste
    Change power adapter
    Test hard drive - replace it with other one
    Test memeory with memtest
    Test temp. - not getting too hot (max 60 C)
    Flash newest bios
    Also i check MB for some liquid spill but nothing, MB is very clean
    Can someone help me or have any idea what to do next?
    ...the quieter you become the more you are able to hear...
  • corrize
    • Apr 2021
    • 272
    • France
    Re: Dell Inspiron 15 33308 random shutdown
    Hello. Random issues are sometime called thermal issues. You can search with hot air (and freeze bomb) by zones on the MB. And if you find zone, you can press with plastic pen for find bad solder.
    • reformatt
      • Feb 2020
      • 1413
      Use Core Temp to rule out CPU getting too hot. But if that is fine, you'll likely have a cracked solder joint somewhere on a passive component. Under a microscope, use a pair of tweezers to nudge the passive components around each buck convertor, paying attention to components on the opposite side of the board for the IC. The plastic housings of some of these machines allow the board to flex and twist so look more toward 1/3 from each side of the board (where twisting forces are at their greatest).
      I had this on a Dell previously where a cap had cracked the joint so was only touching really. This instantly killed the 1.8V supply in that case when it was disturbed.
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        I measured again the cpu and it is not hot, i even check with my finger on the cooler and it is not hot.
        When i tok the board outside case and power laptop i try to poke it with plastic and try to press and i try to gently twist board but it kept working. I the last test i leave laptop to run for several hours and when i came back it was off. All settings are set to “never” go to sleep, hybertnate etc.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          What is the mb code??
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            Cedar Intel-MB
            13269-1
            PWB. FX3MC REV: A00
            And i noticed when i open Bios at startup, laptop can work whole day. When i insert HDD and start windows in shutdown randomly. I test with 3 hard drives with fresh Windows install
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Replace the caps for 3.3V/5V coil with 330uf smd cap. Flash clean me bios. Check again for any result.
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                I reflash the latest A17 bios firmware but no help. And what caps do you mean? The SMD or SMD electrolytic cap?
                Voltages on electrolytic caps are 5.3V and 3.44V is this wrong. The 5V line?
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  And i also notice that when laptop turn off then i need to disconnect charger and plug it back to get started. It wont start on power button unless i reconnect the charger
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    Hey on my board I have a step-down controller 5V/3.3V that produces wrong 5V output (it is 5.3V) The par number is: TPS51225.
                    Can I use TPS51225C and will it work, don't know the difference between TPS51225 and TPS51225C
                    also here is the schematic
                    • mon2
                      • Dec 2019
                      • 14234
                      The schematic uses TPS51225RUKx version.
                      The TPS51225C will have BOTH, the 3v3 and 5v0 LDO rails always on. These are the fixed regulators, not the switching power supplies with the inductors.
                      The original, TPS51225RUK, has only the 3v3 LDO enabled for always ON.
                      Recommend to source the original version from a donor board or offshore from AliExpress.
                      Otherwise, the battery may deplete sooner due to rails not allowing for sleep mode, etc.
                      For testing, it should be fine to use the TPS51225C version in your toolbox.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        I mean PT4501/4502 specifically. Replace them with 330uf tantalum caps.
                        • rtstorm
                          • Feb 2012
                          • 971
                          • Croatia
                          i replaced it with 330uF caps but still, it shut down randomly (cca 10-15 min). And when it shouts down I need to reconnect the charger to be able to start it again.
                          • rtstorm
                            • Feb 2012
                            • 971
                            • Croatia
                            Not it is working fine but still problem with shutdown, it wont start unless i disconnect and reconnect charges (battery is out)
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              Well after some time still the same issue, i tested one again PU4503 and i find out that if i try to measure PWR_3D3V_FB2 or PWR_3D3V_FB1 laptop shut down immediately. After that, the voltage is 2V on that pins (i think there should be 3V). Any idea what to check next?
                              Also, i noticed when it shutdown itself i lose 3V on PS_ID (in input jack). When reconnect charger i get 3V again
                              Today laptop was working for several hours and then shut down.
                              • rtstorm
                                • Feb 2012
                                • 971
                                • Croatia
                                Today arrived new battery. So I find that the charging is not working and I think this is related to the shutdown issue. I check the HPA02224RGRR IC (PU4404)
                                This is the result with batt and without batt.
                                NO BATT
                                1 - ACN -19V
                                2 - ACP -19V
                                3 - CMPOUT - 0V
                                4 - CMPIN- 0V
                                5 - ACOK# -0V
                                6 - ACDET - 2.6V
                                7 - IOUT - 0V
                                8 - SDA - 3.3V
                                9 - SCL - 3.3V
                                10 - ILIM - 3.3V
                                11 - BM# - 3.3V
                                12 - SRN - 2.8V
                                13 - SRP - 2.8V
                                14 - GND - GND
                                15 - LODRV - 0V
                                16 - REG - 6V
                                17 - BTST - 6V
                                18 - HIDRV - 2.8V
                                19 - PHASE - 2.8V
                                20 - VCC - 19.9V
                                WITH BATT
                                1 - ACN -11.8V
                                2 - ACP -11.8V
                                3 - CMPOUT - 0V
                                4 - CMPIN- 0V
                                5 - ACOK# -3.3V
                                6 - ACDET - 2.6V
                                7 - IOUT - 0V
                                8 - SDA - 0V
                                9 - SCL - 0V
                                10 - ILIM - 3.3V
                                11 - BM# - 3.3V
                                12 - SRN - 11.8V
                                13 - SRP - 11.8V
                                14 - GND - GND
                                15 - LODRV - 0V
                                16 - REG - 0V
                                17 - BTST -11.86V
                                18 - HIDRV - 11.8V
                                19 - PHASE - 11.8V
                                20 - VCC - 0V
                                Any idea what to check? The laptop can be turned on with battery and without battery, just the carging is not working.
                                • rtstorm
                                  • Feb 2012
                                  • 971
                                  • Croatia
                                  When the laptop is off the LED charging is on, when i turn ON the laptop then charging stops. Wierd
                                  • rtstorm
                                    • Feb 2012
                                    • 971
                                    • Croatia
                                    I found that in BIOS Adapter type is showing None and after few seconds it show 65W and then again None. I think that the PS_ID line is bad
                                    • rtstorm
                                      • Feb 2012
                                      • 971
                                      • Croatia
                                      Update on this, i notice when i flash a new bios with programmer then charging is working for some time. After some time it stop charging. Then i reflash Bios again and charging is again working for some time. How is this possible?
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        Perhaps heat is at play. When you are changing bios chip, fair amount of heat is applied to desolder/solder the bios chip. Try replacing the caps around charging IC with exact same value as per schematics. I faced this issue on HP LA-A992P mb where charging works for about 30 seconds to 2 mins and then dc jack turns white. I replaced all the caps around charging IC and dc-in fets and its working for more than a year now.
                                          DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:36 PM
                                          DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:30 PM
                                          DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:28 PM
                                          DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
