Asus GL552VW Rev. 2.0 - USB-C Shorted
  • Shito
    • Nov 2021
    • 3
    • España
    I have an Asus GL552VW Rev. 2.0 motherboard with two damaged components by USB-C shorted (totally burned out), but I can't find their references or compatible spare parts.
    In the schematic of the motherboard they are marked as;
    U4706 - (NBS_SOIC_6P_005)
    D4701 - (NBS_SOT323_3P_000)
    Does anyone know the references of these components?
    Thanks in advance
  • mon2
    • Dec 2019
    • 14677
    Re: Asus GL552VW Rev. 2.0 - USB-C Shorted
    D4701 is probably a tvs diode to protect the D+ and D- lines of the usb 2.0 signals.
    The best way to confirm this is to check the schematics if available.
    If not available, highlight the pads of the Diode part.
    One pin will most likely be GROUND.
    Next pin will be D+ but confirm it with the board view file. Then D-. Just an educated guess till I can review against my database. This appears to be SOT-23 or SC-70 package. They are 2 different sizes. This part is very common to source if the guess is right.
    • mon2
      • Dec 2019
      • 14677
      Attached.
      U4706:
      https://www.mouser.com/ProductDetail...IJokVuQMu12A==
      • Shito
        • Nov 2021
        • 3
        • España
        Thank you very much Mon2!
        I found the D4701 and I am happy to agree with your contribution , according that reference I have seen the following spare parts
        https://www.mouser.es/ProductDetail/...hb%252BQ%3D%3D
        https://www.mouser.es/ProductDetail/...%2FVOnvQ%3D%3D
        I see that the component you have located for me (D4706 - BD2243G) is not in stock, although I see a similar one that should work
        https://eu.mouser.com/ProductDetail/...F%252BcA%3D%3D
        I will check with these spare if we fix the problem
        Again, Thank you for the info
        • mon2
          • Dec 2019
          • 14677
          These are very common USB 2.0 current limiting load switches used by many motherboard companies. Host adapter companies on the other hand do NOT use such part to save every penny.
          See attached for the datasheet from ROHM (out of stock part).
          Also the Diodes Inc. replacement that is in stock @ Mouser. There could be others out there as well but have confirmed that this will be a drop in replacement for this load switch. Same pinout, same footprint, same ILIM configuration via the external resistor.
          The key requirement is that you need the ENABLE pin to be ACTIVE_LOW. So when the ENABLE = 0V (logic '0'), the USB load switch will turn ON. That is how the original ROHM part functioned as well.
          Just confirm the details again, in case I missed some detail but 99.9% sure you are ok here.
          Replace with the following Diodes Inc. USB load switch:
          AP22652W6-7
          https://www.mouser.com/ProductDetail...fjrcu2WF1Us%3D
          Update:
          LOL. I think your choice will also work. Order a few of both versions. From a quick glance, the difference is that the original USB load switch had a discharge feature to quickly remove any potential on the Vbus rail when the laptop is OFF. Not a big feature to lose.
            ASUS ROG GL552VW-DH71-HID4 Notebook Specification for Upgrade or Repair
            This specification for the ASUS ROG GL552VW-DH71-HID4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL552VW-DH71-HID4 boardview and GL552VW-DH71-HID4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 06:30 AM
            ASUS ROG GL552VW-DH71-HID1 Notebook Specification for Upgrade or Repair
            This specification for the ASUS ROG GL552VW-DH71-HID1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL552VW-DH71-HID1 boardview and GL552VW-DH71-HID1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 06:08 AM
            ASUS ROG GL552VW-CN444T Notebook Specification for Upgrade or Repair
            This specification for the ASUS ROG GL552VW-CN444T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL552VW-CN444T boardview and GL552VW-CN444T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 05:30 AM
          • FriedFred
            ASUS ROG STRIX G713IC-HX041W, Mainboard G513-MP-GBM, battery shorted out
            by FriedFred
            6050A3249305-MB-A01
            2021-11-05
            Hello, everyone!
            I have some trouble with the G513-MP-GBM board, it's from an ASUS ROG STRIX G713IC-HX041W.
            The total current consumption was about 200mA. The 0.8 Volt rail at the CPU was correct working.
            But the power button has not been pressed...
            I found some spurious solder between the pads 6 (VRA_SVT) and 7 (APU_PWR_EN) of the PWM-controller, "U66000".
            Which can explain why this power rail has been starting without...
            01-19-2025, 09:00 AM
          • OOF DIO
            ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
            by OOF DIO
            (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
            (Had 3 problems, now just 1)
            I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
            I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
            I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
            04-19-2025, 05:03 PM
