sony mbx 266
  • sundarkanini
    • Aug 2017
    • 155
    • india
    sony mbx 266
    after discrete uma graphics
    brightness not increasing properly
    slightly dim not increase full brightness
    need help guys
  • mon2
    • 14679
    Re: sony mbx 266
    Post the schematics (if available).
    Unable to locate the MBX 266 schematics in my database.
    Most likely the LCD panel is a LVDS interface. There should be a backlight pin on the display panel connector. That pin and voltage needs to be reviewed. Check for any damaged pins / dirty contacts / corrosion. Clean with alcohol which never hurts. Reseat and test again.
    • Carlos#2003%
      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
      by Carlos#2003%
      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
      02-15-2024, 07:52 PM
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-06-2024, 05:27 AM
    • sviru
      Dell P1110 Sony G500 Trinitron fix - not brightness!
      by sviru
      Hi guys I have issues with my "new" P1110.
      The screen is not horizontally centered. From the start. I need to shift the screen and make it bigger to fill the screen. No matter what source xbox/pc/laptop.
      There is also a big distortion you can see here.
      https://ibb.co/NCGKs7N
      Also the screen has a little red shift in the blacks.
      Any ideas? Screen is not too bright.
      08-30-2023, 08:03 AM
      Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
      This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
      09-06-2024, 05:30 AM
