HP ProBook 450 G1 PN: E9Y39EA not powering on
  • BIOSrookie
    • Jul 2021
    • 13
    • Austria
    I have a problem with notebook HP ProBook 450 G1 PN: E9Y39EA - it doesn't power on.
    When I plug in the original adapter the charging LED flashes once white and twice orange (white – orange – orange). I get the same result with different adapter and if I remove processor.
    I tried HP recommended routine, removing main battery, CMOS battery, holding power button 12 seconds etc., with no improvement.
    Has someone experience with this problem? I checked HP documents and charging LED error codes are not mentioned anywhere.
    Thanks.
    • 20990
    Re: HP ProBook 450 G1 PN: E9Y39EA not powering on
    Run a battery calibration from the hardware diagnostics menu https://support.hp.com/us-en/document/c00259897
    Check your battery barcode number as well to see if its part of the battery recall,you might get a new battery for free https://h30686.www3.hp.com/?lang=en-US
    • BIOSrookie
      • Jul 2021
      • 13
      • Austria
      As I said, the computer does not power on, I cannot run a battery calibration as you suggested.
        • 20990
        missed that part .
          • 20990
          Whats the motherboard part number
          • BIOSrookie
            • Jul 2021
            • 13
            • Austria
            HP Spare: 734084-001
            I found the schematics on the forum.
            https://www.badcaps.net/forum/showth...t=48.4YW05.011
            There is 19V present on the main power rail.
              • 20990
              test the voltage on all large grey square coils
              • BIOSrookie
                • Jul 2021
                • 13
                • Austria
                I measured voltages on large grey coils with adapter plugged in, see pictures attached.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Adapter blinking pattern is ok for probook. Nothing wrong there. Check RTC section to begin with.
                  • BIOSrookie
                    • Jul 2021
                    • 13
                    • Austria
                    Could you please help me with what and how should I check in RTC circuit?
                    • BIOSrookie
                      • Jul 2021
                      • 13
                      • Austria
                      When power button is pressed, power LED, charge LED and caps lock LED blink white once.
                      But only when button is pressed, blinking does not repeat unless button is pressed again.
                      Could this based on HP LED error codes indicate a faulty processor?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Check RTCRST# & SRTCRST# first. No power should be connected(adapter as well as battery) while measuring these voltages. Only CMOS Cell with 3V should be attached.
                        Btw, Do you have a dc supply?? If yes, report the consumption offline mode and again when you try to turn it on. Is there any difference in consumption??
                        • BIOSrookie
                          • Jul 2021
                          • 13
                          • Austria
                          I tried to check RTCRST# & SRTCRST# on PCH (chipset) testpoints, but all were 0V (I attached picture where I measured). Should I check other testpoints?
                          I do have dc supply, I cut old connector from non-working adapter and tried to apply voltage through it to the board. Since no lights turned on, I tried again with working adapter and figured out that original adapter has three lines = 19V, 5V and ground. Because I only have one dc supply I am not able to supply two different voltages into the board.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            The RTCRST# & SRTCRST# measurement is not done on top of PCH. There is likely to be trangle shaped jumper near pch and maybe labelled as CMOS OR JCMOS etc. If you have difficulty finding the test point, post clear picture of pch area-top+bottom side.
                            • BIOSrookie
                              • Jul 2021
                              • 13
                              • Austria
                              I found the triangle you mentioned and measured the voltages, see attached picture.
                              What is the next step?
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                I'm afraid, thats not the triangle i was talking about. Better you post clear pic -top+bottom side of PCH.
                                • BIOSrookie
                                  • Jul 2021
                                  • 13
                                  • Austria
                                  I tried to make as clear photo as possible, but PCB coating is very reflective.
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    G1901-That's the point where i asked you to measure. One side will be GND, The other should show close to 3V. The measurement must be taken without any power(adapter+battery), only cmos cell connected.
                                    • BIOSrookie
                                      • Jul 2021
                                      • 13
                                      • Austria
                                      I measured voltage over G1901 as per your instructions – it is in fact 3V.
                                      I gathered additional info about events before failure. Laptop was on battery charging a phone over USB port and the laptop battery run off. After this the laptop could not be turned back on.
                                      Can some PMIC in USB port area be the culprit for laptop not turning on?
                                      • serious_electron
                                        Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                        by serious_electron
                                        Hello Everyone!
                                        I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                        06-28-2025, 02:57 PM
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • Julian Bailey
                                        HP ProBook 445 G8 Battery not charging
                                        by Julian Bailey
                                        Hi all
                                        We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                                        The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                                        I have gone around the board with a MM and cant find anything
                                        Windows shows the battery fine,...
                                        10-11-2024, 10:34 AM
                                      • mkdj
                                        ASUS X571 no power : battery issue?
                                        by mkdj
                                        Mark and model: ASUS X571
                                        Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                        Tests already made:
                                        - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                        - I have removed...
                                        07-14-2025, 09:16 AM
                                      • mohamed mm
                                        DELL Inspiron 15 3567 not powering with battery
                                        by mohamed mm
                                        Hello Everyone, I hope you are all doing well,
                                        I have a Dell laptop, Inspiron 15 3567, it's only powring up with the adapter not with the battery, but after it's on I can remove the adapter It works fine with the battery, so only the problem is it does not start with the battery even if its attache with the laptop.
                                        battery condition is excellent and the adapter is original, both are detected in the bios. ( sometimes a laptop doesn't start until I disconnect the battery and reconnect it again), I have updated the bios but nothing has changed.
                                        Here's my reading with...
                                        08-05-2023, 07:08 AM
