HP Pavilion 17-ab091ms - white charging light, but no power
  • BMCappelletti
    replied
    Re: HP Pavilion 17-ab091ms - white charging light, but no power
    What you wrote here, indicates AD_ID problem. This is what i mean by blinking at dc jack. Solid white light when plugged in, try to trigger, light goes down and back.
    Got it.
    I tried just once. Hope I shorted the right pins. But I can try to replicate it again.
    But, if it is what you say, what should I do next?
  • mcplslg123
    replied
    Originally posted by BMCappelletti
    Hmmm white light just went down and on again.
    CPU not getting hot.
  • BMCappelletti
    replied
    White light at dc jack blinks when you try to turn it on-Right?? That most probably indicates problem with AC-Adapter not properly recognised. Try with another HP Original adapter, if possible, check ADP_ID circuit thoroughly. I Think this model may require a 90W charger.
    No, it does not blink. It's a solid white light.
    The original charger is a 120W one.
  • mcplslg123
    replied
  • BMCappelletti
    replied
    Originally posted by tahc81
    Please note that BIOS chip is 1.8V device, so you'd need 1.8V SPI adapter. And no, incorrect/broken BIOS image can't cause short on power rail. If the EC BIOS is a part of it, it could make some other issues, but at least 3.3V is completely independent of BIOS and EC.
    Hi. I was re-reading the thread, to check if I missed something or had a clue on what to try next, and I think the BIOS on it is 3.3V, not 1.8V.
    I even found it for sale stating 3.3V.
  • BMCappelletti
    replied
    Pin#16 to GND should turn it on. Red probe should be on GND and you need to touch pin16 with black probe.
  • mcplslg123
    replied
  • BMCappelletti
    replied
    If I wanted to try turning it on without the daughter board, where the power button is, which pins on the daughter board connector I should short?
  • BMCappelletti
    replied
    Btw, Did you checked LID Switch??
    I mentioned it here (at least maybe it is this)
    https://www.badcaps.net/forum/showpo...3&postcount=12
    How should I exactly check it?
    If you mean a specific LID switch board, this model does not seem to have it.
  • mcplslg123
    replied
  • BMCappelletti
    replied
    I dont think its shorted. What is the exact resistance on those caps?? Remember, caps will show very low resistance near cpu/gpu area and even lower with onboard soc. Resistance above a couple of Ohms is not likely shorted.
    Ok. Got it.
    Those around CPU are like 1.8k ohms.
    So, I'm back to squase zero. Almost. :p
  • mcplslg123
    replied
  • BMCappelletti
    replied
    Going by your thread from beginning, i still could'nt understand which "SHORT" you are talking about. can you please elaborate where do you find short??
    Initialy, on these caps marked in red and green.
    On the board view I have they could be PC2012/PC2013/PC2014 and PC6009/PC6010.
    After cleaning this in the back of the board,
    the ones in red are not shorting to ground anymore. The ones in green were still and I removed them. The pads are still shorting to ground.
    And, after all these days tinkering with the board, I can find lots of caps shorting, including all those around the CPU area, in the back of the board.
  • mcplslg123
    replied
  • BMCappelletti
    replied
    Well... I got the voltage injector.
    Injected 1.2V on the pad from one of the caps I removed. The mobo is drawing 0.076 amps, which seems very low.
    I could not feel anything hot on the board.
    Should I up the voltage to 1.8V, which is the next step on the device?
  • BMCappelletti
    replied
    Just to add...
    I was watching some BIOS reflash videos and the guy mentioned that there should be 3V on pin 8.
    According to the board view I have it should, indeed. And ground on pin 4.
    I could find ground on pin 4 but on pin 8 I get only 0.08V.
  • BMCappelletti
    replied
    I think the fried BIOS chip is like a Yeti = nobody ever seen him Generally speaking, BIOS issue usually stands for corrupted data preventing PC from starting. If you see BIOS shorted (pins 4 & 8), it's usually something else shorted, not the BIOS chip itself. 3V3 and 1V8 as well are connected to other components, and it can vary from single capacitor or diode to a mosfet or CPU/chipset. When 3V3 is not present and shorted, I usually using voltage injection and checking for the heat spot to identify the short.
    Note: if there's a short on 3V3, you will fail to read/write BIOS chip
    I will have a voltage injection tool tomorrow. So for now I was trying to find the issue with testing.
    But it does not seem too easy.
  • BMCappelletti
    replied
    That reminded me that the board is shorted-Where do you find it is shorted??
    https://www.badcaps.net/forum/showpo...19&postcount=3
    Maybe an issue with the 1V1 line, as both this caps should have 1V1 on it?
  • tahc81
    replied
    I think I'm fine.
    Still need to check how to do all that.
    But if a broken BIOS cannot result in a short, so I don't see a point on trying to reflash it. Or did I get it wrong?
  • mcplslg123
    replied
    HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
    This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
    09-12-2024, 03:44 PM
    HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
    This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
    HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
    This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
    HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) Pavilion 550 i5-6400 Specification for Upgrade or Repair
    This specification for the HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) boardview and Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
    HP Pavilion Pavilion p6560be-m Desktop PC Bundle Pavilion p6500 E6600 Specification for Upgrade or Repair
    This specification for the HP Pavilion Pavilion p6560be-m Desktop PC Bundle can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6560be-m Desktop PC Bundle boardview and Pavilion Pavilion p6560be-m Desktop PC Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
