Asus GL752V Blowing new MOSFETS
  • BlkMolly
    • Jul 2021
    • 22
    • US
    Hello All I wonder if anyone can help me,
    I'm trying to fix an Asus GL752V.
    The laptop turned on with only the BATT/PW LED's showing on the front, no display/POST.
    I found that a MOSFET near the top left side of the SSD bay had blown rather aggressively, (black skid mark see pics) I removed the blown MOSFET and tested the one to the left of it, also blown (short on all pins), I tested board for shorts after the removal all seemed ok.
    I replaced both MOSFETS and did a short circuit test all still good (well low resistance on right FET from GtoS red flag?)
    I powered on the laptop without memory and the PW LED came on, so I thought all was good, I then installed a memory module turned on again and no power no lights, checked FET's and found both to be shorted AGAIN!
    Please could someone guide me to a solution.
    PS. I found on power connect (not pushing the power button) after the FET replacement the southbridge was warm, I'm guessing this is not normal and I think its the death knell of this laptop, Is it worth continuing with it?
    Any advice suggestion.
    Thanks.
    • 21960
    Re: Asus GL752V Blowing new MOSFETS
    Is the silkscreened motherboard part number GL752VW REV 2.1
    • petehall347
      • Jan 2015
      • 4445
      • United Kingdom
      sometimes resistors go high and also ceramic caps are known to go short . either might be your problem
      • mon2
        • Dec 2019
        • 14677
        Posting some details from the boardview for this logic board.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3628
          • slovakia
          replace ic and mosfets
          • BlkMolly
            • Jul 2021
            • 22
            • US
            Hello SMDFlea,
            Yep that is the exact one.
            • BlkMolly
              • Jul 2021
              • 22
              • US
              Hello petehall347,
              I did check nearby caps, and used voltage injection (1.2v max) at the stated site, however I didn't find any shorted caps and I'm unsure of the values of the resistors as I have no board info, there is a resistor connecting GtoS on the original blown FET I believe it is very low resistance.
              All that said, I need to remove the blown FET's and recheck the board as things may have changed since the FET's blow.
              • BlkMolly
                • Jul 2021
                • 22
                • US
                Hello mon2,
                Thanks for the pictures, however I dont have any frame of reference for the given pics, I dont know the location or what the components are.
                • BlkMolly
                  • Jul 2021
                  • 22
                  • US
                  Hello ktmmotocross,
                  Are you talking about the southbridge I mentioned, or the IC near the blown FET?
                  Is it a FET driver or a buck controller?
                  • BlkMolly
                    • Jul 2021
                    • 22
                    • US
                    Sorry mon2 I had my "stupid" glasses on, I see what it is thanks.
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3628
                      • slovakia
                      Originally posted by BlkMolly
                      Hello ktmmotocross,
                      FET is driven by controller. so u can tell it is FET controller or buck controller.
                      replace controller ic with all mosfets, but offcourse first check for shorts before and after install, to be sure
                      • BlkMolly
                        • Jul 2021
                        • 22
                        • US
                        Hello Guys,
                        I have done some more digging and found this (see pic attached) DDR PSU controller
                        I guess for some reason the two FET where energized at the same time resulting in massive current passing through them so BOOM!
                        I would like to know why so I may put a scope on the controller and view the high and low gate drivers (maybe just a meter in continuity will work to see if there is a short?)
                        Am I on the right path and is there anything else I should consider?
                        Anyway thanks to all for there input and ktmmotocross for suggesting the controller.
                        PS I wonder if my memory module is ok, if it got hit with 19v I doubt it.
                        Is there a way of testing it without putting another laptop in danger?
                        • BlkMolly
                          • Jul 2021
                          • 22
                          • US
                          Anybody know the value of PR8604 in attached picture, I'm thinking it might be about 10k?
                          Many thanks.
                          • BlkMolly
                            • Jul 2021
                            • 22
                            • US
                            Bad news about this one, I found the CPU has a short on the 1.2v rail :-(
                            Thanks for all the help.
