Weird problem with keyboard backlight in Thinkpad T470
  • szogun
    • Jun 2017
    • 18
    • Poland
    I`ve bought two T470, both of them has a backlight keyboard, and in one of them (lets name it computer A) it doesn`t work.
    There is no "welcome light up" and no reaction to Fn+Space combination. My first suspect was the keyboard itself, so after checking the connectors, cleaning them na ribbons which didn`t help, i`ve swapped the keyboard as i have second computer (lets name it B)
    From now, things are getting weird.
    Both of keyboards started to work as it should. Welcome light up, switching on and off, changing brightness etc.
    Computer B with keyboard from A works flawlessly.
    Computer A doesn`t. After few cycles of getting into sleep mode, backlight stopped to work. When i pressed Fn+Space, the onscreen notification singalized changing state of backlight but keyboard itself didn`t respond (it was off).
    After reboot it`s back to square one. No backlight, no notification.
    Swapping keyboards didn`t help this time, however both of them works fine in computer B.
    BIOS version in both of them is 1.67.
    A i running on Fedora, B is running W10.
    After all, i think that there is problem with KBD_BL_DTCT signal, but VCC3M is ok, so maybe MEC1653 is faulty?
    Have anyone have similiar problem?
    How is the detection of backlight works? Can i override this?
  • mon2
    • 14340
    Re: Weird problem with keyboard backlight in Thinkpad T470
    Since they are the same system, can you take the HD/SSD with Win10 from Computer B and test on Computer A ?
    Only to confirm the issue is not s/w related.
    Otherwise:
    1) Monitor the voltage of -KBD_BL_DTCT on the working Computer B. Believe the '-' prefix = Active LOW ? But confirm this logic level.
    Under the same condition, what is the value on Computer A ?
    When the backlight is not working, what are the values for this rail on Computer A ?
    2) Monitor the voltage of KBD_BL_PWM which is responsible for the backlight intensity as you increase / decrease with the keyboard action.
    What are the voltage values on Computer B ? Computer A ?
    3) Investigate the voltage on -LID_CLOSE for the working computer and compare the reading on the non-working Computer A. Is the opening / closing of the LID a factor ?
    4) Be sure that the keyboard mating connector and cable are clean and firmly seated onto the logic board.
    Since the MEC1653 controls many other functions like BACKLIGHT_ON (LCD Display) and others, believe this component is working.
    • szogun
      • Jun 2017
      • 18
      • Poland
      Regretfully, no luck.
      Yes, it`s active low.
      I`ve done that before, and at first everything looks the same, BUT what i didn`t check, is voltage on that rail when computer is turned off.
      Computer A hits 3,3V, when in computer B it`s 0V.
      Computer A: 0V, Computer B: 0V, 1V, 3,3V dependent from brightness of backlight
      That led me, to measure voltage on when computer is turned off.
      checked,no problems here
      It`s true, but isn`t it also responsible for turning VCC3M on and off? If it failing to do that, maybe this is the source of problems.
      • neth524
        • Jul 2022
        I know this is an older thread, so sorry in advance.
        I am having a very similar issue. I have a two T470, one is I5-6300 and the other is I5-7300. They both now have a backlight keyboard, but the 6300 is the only one that lights up and that Lenovo Vantage recognizes as a backlit. I have swapped the boards around, so I know that both boards do light up correctly. Both are fully BIOS updated and win10 updated. I don't know hardly anything about Linux, but I did make a usb boot for ubuntu, and found the right drivers for the light but didn't work there either. It also doesn't light up in the BIOS. I am not sure what the issue could be. I checked the fuse for the keyboard, and it works. I am now leaning towards the MEC1653, but I have no idea if 1, that is it replaceable, or 2, if it is even worth doing.
        szogun, were you able to find a fix for your issue?
        • clincher
          • Feb 2022
          • US
          Apologies again for digging up an old thread, but I just ran into this issue as well. Everything checked out with voltages, however after a some serious banging my head against the wall , I inspected the JTP1 connector that contains KBD_BL_PWM and -KBD_BL_DTCT.
          On inspection under a microscope, I could see some of the pins on the top layer had become bent up ever so slightly (probably from removing the keyboard and not releasing the clips instead of sliding the connector out). I gently bent them back down to give some more pressure to the connection and BOOM! that was it. Powered the machine back on and the backlight is working agin.
          I doubt either of you have your boards still, but hopefully this helps someone else who comes along in searching.
          Cheers!
          • Maxpower3
            Brand name and Model Type for Lenovo error 2202 product name is invalid
            by Maxpower3
            Info for error 2202 LenovoThinkPad models and type
            Extract from ThinkPad Maintenance Utilities Configuration File
            plnsrv.ini Version 1.01
            Some information that may be useful
            There must also be missing models, add them to the list if you know of any.
            Code:
            brand name
            20B1=ThinkPad Edge E445
            20B2=ThinkPad Edge E545
            20BC=ThinkPad Edge E145
            20BM=ThinkPad X140e
            20BL=ThinkPad X140e
            20A3=ThinkPad X230s
            20AH=ThinkPad X230s
            20AK=ThinkPad X240s
            20AJ=ThinkPad X240s
            02-21-2024, 10:27 AM
            Lenovo ThinkPad T470 + ThinkPad USB Dock Notebook T Specification for Upgrade or Repair
            This specification for the Lenovo ThinkPad T470 + ThinkPad USB Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T470 + ThinkPad USB Dock boardview and T470 + ThinkPad USB Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
            09-06-2024, 06:10 AM
            Lenovo ThinkPad ThinkPad T14 Gen 1 (AMD) Notebook T Specification for Upgrade or Repair
            This specification for the Lenovo ThinkPad ThinkPad T14 Gen 1 (AMD) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad T14 Gen 1 (AMD) boardview and ThinkPad T14 Gen 1 (AMD) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
            09-07-2024, 05:20 AM
            Lenovo ThinkPad ThinkPad X1 Fold Gen 1 Ultrabook X Specification for Upgrade or Repair
            This specification for the Lenovo ThinkPad ThinkPad X1 Fold Gen 1 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Fold Gen 1 boardview and ThinkPad X1 Fold Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            Lenovo ThinkPad ThinkPad P15s Gen 2 Notebook P Specification for Upgrade or Repair
            This specification for the Lenovo ThinkPad ThinkPad P15s Gen 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad P15s Gen 2 boardview and ThinkPad P15s Gen 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-07-2024, 05:00 AM
