Lenovo g40-30 nm-a311 voltage normal but cant turn on
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    Flash bios done, but stil didn't work
    And the LED power always blinking bro
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo g40-30 nm-a311 voltage normal but cant turn on
    No measurements while seeking help?? How we can help if you dont provide any information??
    • pajdek
      Lenovo Y700-17ISK turn on and off
      by pajdek
      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
      09-20-2023, 02:49 AM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • g1150
      Lenovo G565 Laptop , LCD not turn on, external terminak ok.
      by g1150
      Lenovo G565 Laptop onboard LCD Display does not turn on.
      Only works with external Monitor.
      I am trying to verify that the LCD signals from the motherboard are ok.
      The LCD was working, but over time happened to not turn on more frequently.
      Now dead.
      Possibly the cable from MB to LCD is broken somewhere.
      I just wonder how it is detected if external or internal monitor shall be activated ?
      I found the following schematic on the net:
      Problem 2:
      The graphics chip ATI Mobility Radeon HD5470 seems defective.
      On Win7...
      05-07-2025, 11:51 AM
    • BMCappelletti
      Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
      by BMCappelletti
      Hi everyone.
      Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
      Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
      Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
      02-18-2025, 12:22 PM
    • Evgenii999
      Laptop Lenovo IdeaPad 3 15ITL05 doesn’t turn on.
      by Evgenii999
      I need your advice in diagnosing a motherboard issue on a Lenovo IdeaPad 3 15ITL05, motherboard HS45A/HS55A Rev 1.0 NM-D461 (2020-11-02).
      Symptoms:
      The laptop does not power on and does not respond to the power button.
      Background:
      According to the owner, her child was playing on the laptop when it suddenly shut down.
      What has been done so far:
      Original charger is missing; the non-original one was tested and found faulty (0 V output).
      Using a lab power supply (20 V, 0.5 A) — no activity on the board, no LEDs, no standby voltages....
      10-25-2025, 06:07 AM
