x407ma rev 2.1 charger IC?
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Hi hope someone can help me I have a burn charger Ic but I dont know what tpye of cahrger Ic was this unit is using.
    I also tried a BQ24780S but I was getting a 6V at may AC ok Signal , its very hasrd beacause I cant find a schematic for this unit.
    I tried to test the resistor that is close to pin 5 of the ACOK of the Ic it values around 0.3 omhs is it normal?
    • 22097
    Re: x407ma rev 2.1 charger IC?
    boardview - https://www.badcaps.net/forum/showthread.php?p=1068431
    • motormayhem
      Lenovo T460 Only Charges on One Charger
      by motormayhem
      Laptop Question
      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
      05-12-2023, 01:46 PM
      ASUS X407MA-BV139T Notebook Specification for Upgrade or Repair
      This specification for the ASUS X407MA-BV139T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X407MA-BV139T boardview and X407MA-BV139T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
      09-06-2024, 09:17 AM
      ASUS X407MA-EB210T Notebook Specification for Upgrade or Repair
      This specification for the ASUS X407MA-EB210T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X407MA-EB210T boardview and X407MA-EB210T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
