Asus A555L doesn't detect any sata device
  • Francisco.s
    • 686
    • Spain
    Asus A555L, motherboard X555LD doesn't detect any sata device.
    Original bios is a X555LJ, but I have flashed a X555LD and behaves the same way.
    In secure boot menu, the secure boot option is grayed and can't be enabled.
    There are no pulses in sata lines. (ie. SATA0_HDD_TX_D or SATA1_ODD_TX_DP)
    Boots linux from usb without problems, but not detect any sata either.
    Any advice?
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Asus A555L doesn't detect any sata device
    Mezzanine connector for daughter board is often a problem.
    • Francisco.s
      • 686
      • Spain
      Thanks piernov, it doesn't work with an adapter (caddy) with a sata disk connected in the dvd slot.
      I'm afraid it could be a damaged cpu. (with pch integrated)
      Perhaps it's a problem with a resistor or capacitor related to cpu sata circuit.
      I only have the boardview, and I think there are no schematic for this motherboard.
        • 20878
        These are the type of connector that piernov mentioned - https://www.aliexpress.com/i/33024147419.html
        Your bios version is X555LJ but what model is printed on the barcode sticker - https://www.badcaps.net/forum/showthread.php?t=96604
        • Francisco.s
          • 686
          • Spain
          Yes I know this conector, it fails in some asus models, but I think this is not the case.
          X555LJ is what is printed on the barcode sticker.
          I will try anther X555LJ bios from asus website.
          Thanks to razor_amd for that good job.
