Asus X1500e does not recognize M2 or Sata SSD after bios update.
  • renato.macdias
    • Nov 2021
    • 10
    • Brasil
    I have this Asus notebook that wouldn't turn on. Searching on a forum here in Brazil, I found a BIOS that gave an image, but it stopped recognizing the nvme SSD that came from the factory on this notebook. I tested other m2 SSDs but none of them recognized it. So I ordered the flat one from Aliexpress to connect a SATA SSD, and to my surprise it's not recognizing the SATA either.
    I'll leave here the backup I made of the original BIOS, before rewriting it.
    If anyone can check it for me, I'd be really grateful.​
    • 21457
    Please read the rules and post as text your laptop serial number
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • DynaxSC
      GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
      by DynaxSC
      I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
      There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
      The board is generally working now, all PCIe ports are working, Windows installs normally.
      However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
      The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
      03-10-2025, 12:27 PM
    • davidebeatrici
      Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
      by davidebeatrici
      I had 3 people contact me in a week because Windows suddenly didn't boot:
      As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
      The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
      Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
      06-17-2025, 12:59 PM
    • jinki_dadou
      ASUS ExpertCenter D700MD need update bios
      by jinki_dadou
      helle
      in have asus desktop
      model : D700MD-5124000950
      CPU i5 12400
      I wanted to upgrade the processor i7 13700
      when I change the processor show black screen and fan spinning fast
      i ask asus technical support
      the answer : include microcode in the latest update bios
      he give me file 1 update bios
      2 microcode
      2 fils in tha attachments please help me
      ( sorry for my dab english )...
      05-18-2025, 02:20 AM
    • mikeybass
      by mikeybass
      04-23-2025, 04:30 PM
