elitebook 820 G3
  • nassih
    • Oct 2015
    • 276
    • morocco
    elitebook 820 G3
    hello
    i have an hp 820 G3 motherboard 6050a2725001-mb-a01 turn on with no display num lock is blinking 5 time and,i have flashing bios,change the RAM,all voltage is pesent.idont now if bios or other part in motherboard
    pleas help
  • mon2
    • Dec 2019
    • 14189
    Re: elitebook 820 G3
    5 blinks = system board error.
    https://www.badcaps.net/forum/showthread.php?t=95754
    see the posted post codes chart.
    What is the history of this logic board? Any liquid spills ?
    Just decided one day to start with this 5 blinks code ?
    • nassih
      • Oct 2015
      • 276
      • morocco
      no liquid damage,no short,the customer informed me that the laptop is often in extended sleep mode
      • mon2
        • Dec 2019
        • 14189
        https://www.bestsoltips.com/solved-h...-continuously/
        Be sure that this is not a thermal issue. Clean vents, check and replace with good heatsink paste.
        https://www.reddit.com/r/elitebook/c...tent=post_body
        https://www.badcaps.net/forum/showthread.php?t=88845
        • nassih
          • Oct 2015
          • 276
          • morocco
          i have 2 coil without voltage in
          • mon2
            • Dec 2019
            • 14189
            1) Power down. Remove the adapter and battery.
            2) Meter in resistance mode (200 ohms scale).
            Check the resistance to ground for each of these 2 coils that are missing the voltages.
            What is the resistance for each coil ?
            3) Post clear pictures of each coil and local mosfets and switching power supply IC. Post the markings on each mosfet and IC that is linked to each coil.
            • nassih
              • Oct 2015
              • 276
              • morocco
              resistance o 2 coil =6.7ohm
              • nassih
                • Oct 2015
                • 276
                • morocco
                this datasheet of the ic u66310 driving the 2 mosfet then sw1,sw2 goes to coil
                • nassih
                  • Oct 2015
                  • 276
                  • morocco
                  voltage on NCP81152:
                  BST1:5v
                  PWM1:2.0v
                  EN1:4.9v
                  VCC1:5.1v
                  BST2:5v
                  PWM2:2.0v
                  EN2:4.9v
                  VCC2:5.1v
                  DRVL2:0v
                  GND2:0v
                  SW2:0v
                  DRVH2:0v
                  DRVL1:0v
                  GND1:0
                  SW1:0v
                  • mon2
                    • Dec 2019
                    • 14189
                    Is the mosfet driver linked to Q66310 & Q66320 in the shared photo?
                    Are the measured voltages with a connected battery?
                    If not, measure again with the battery to see if the following lines change their values (with battery):
                    DRVL2:0v
                    SW2:0v
                    DRVH2:0v
                    DRVL1:0v
                    SW1:0v
                    • nassih
                      • Oct 2015
                      • 276
                      • morocco
                      yes sir
                      same voltage battery in
                      • mon2
                        • Dec 2019
                        • 14189
                        Check to see if the mosfets are shorted.
                        Remove all power and battery.
                        Check the resistance between source and drain for each of the above mosfets.
                        Repeat measurements for source & gate; then drain and gate for each.
                        • smali
                          • Sep 2014
                          • 287
                          • Pakistan
                          same issue with my 820 g3 laptop... i tried to reflach the bios shared in this form.. both the above mentioned both coils have no voltage..
                          • m2farid
                            • Dec 2021
                            • 32
                            • France
                            Hi I have 3 laptops and all 3 got mad the fan is spining and the pcs get warm. i suspect a virus on my bios as I replace hard drives and fresh install of windows 10 and got same problem. Could you please look at this bios and clean it if necessary. I need a good clean bios file
                            Many thanks for all.
                            PS: I don't need password remove as there is no password
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              There is dedicated subforum for bios requests.
                                HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                09-07-2024, 05:50 AM
                                HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                09-07-2024, 05:20 AM
                                HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                This specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
