Lenovo Y520 151KBN (i7) Graphics NVIDIA GTX 1050 problem ...
    Please help if anyone knows what this is about ..
    the laptop works well but DOESN'T SEE the NVIDIA GTX 1050 GPU
    it is not even in the device manager.
    Tried a few bios but also ... GPU chip I think is quite correct and not much used ...
    it happened that suddenly there is no Nvidia GPU and if it is on the board ..
    Please help he doesn't know what to do to him
    I ask the Administrators to put the topic in the right place if I was wrong ....
    Re: Lenovo Y520 151KBN (i7) Graphics NVIDIA GTX 1050 problem ...
    Try this type windows+R in the box type or paste this devmgmt.msc, inside that window in the "view" tab select the option "Show hidden devices".
    Does your device appear as hidden when you perform these steps?
      Thanks, I'll try and let you know
        Tried it .... no hidden devices
        Does anyone have another idea ???
          Hardware issue usually caused by bad soldering on the CPU. The GPU gets physically disconnected from the bus. We used to see this a lot with water damaged boards.
          A working TV? How boring!
            If it is the GPU basically you will have to change the chip if it is bad, or do a reballing if it is working fine.
            To test if the chip is bad soldered, first do a good cleaning with isopropyl alcohol, if it is liquid or moisture damage apply an ultrasonic wash if you have the machine.
            After cleaning well you can do a small reflow, at 200 ° at most 1 to 2 minutes at most and test if the board gives video.
            The reflow is not a solution, if it gives video it will be only for a while, if or if you will have to change the chip or do reaballing.
            If you don't know how to do any of the above, take it to a technician.
