Technical question - Macbook Air BIOS change
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Hello guys,
    I see here on the form a lot of questions about Macbooks and there are a few very knowledgeable people here too. I would like to know the following.
    I have MBA A1466 year 2015 with 820-00165 board. I suspect the BIOS/SPI ROM is corrupted. I have another, but from year 2017, the same board, but i7 CPU.
    Is it possible to read BIOS from A1466 2017 and write to the chip from A1466 2015? Will this work?
    I have read on many threads about PC laptops, that ME (Intel Management Engine) must be cleaned or pC will not work or work unpredictably.
    Does this also apply to Macbooks?
    Can I use a BIOS file from the internet that corresponds to the production year as my laptop?
    This part is not really clear to me and I would appreciate if someone has time to explain when these operations are possible and recommended.
    Thank you!
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: Technical question - Macbook Air BIOS change
    Even on macs, ME would need to be cleaned.
    You could use the 2017 dump but you would need to clean ME and replace VSS region with the one from 2015 (to keep the original SN).
    • Adenitz
      • Jan 2021
      • 122
      • Congo
      Would I need to do this if I find the board with identical specs (i5 CPU and RAM)?
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        Yes because that other board has different SN and different (let's say dirty) ME.
        • 5chematic
          • Jun 2019
          • 77
          Originally posted by Adenitz
          Hello guys,
          Thank you!
          Do you still have the bios that you suspect is corrupted? ..post it here I will take a look.
          • Adenitz
            • Jan 2021
            • 122
            • Congo
            Thank you 5 chematic, I really appreciate it. I already pass the board to another guy that is more experienced with the BIOS programming.
            He has a few BIOS dumps for each Macbook board, so it is probably fixed by now (if the problem was with BIOS in teh first place)
            I must admit, this whole thing about BIOS dump, clean ME region etc is not quite clear to me, so I didn't get involve too much.
            • yura8
              Need BIOS/EFI dump for MacBook Air A1466 2015 EMC 2925 (8gb)
              by yura8
              Hi there! I have not so usual situation...
              I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
              My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
              P.S. If you have else any ideas about repair, or you had a similar...
              12-20-2024, 02:31 PM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • sidthesloth
              NEED HELP WITH MACBOOK AIR BIOS A1466 820-00165A
              by sidthesloth
              I HAVE A MACBOOK AIR A1466 820-00165-A THAT IS BIOS LOCKED I WAS ABLE TO DUMP THYE ORIGNAL TO UNLOCK IT AND ION THS PRFOCESS MY CAT GOT ON MY KEYBOARD AND WAS ABLKE TO ERASE THE CHIP ASND THE FILES I HAD SO IM STUMPED. I HAVE A COUPLE BIOS THAT IVE DOWNLOADED AND CHANGED THE SSN BUT WE
              HEN I FLASH THEM TO CHIP AND TRY TO BOOT THE MACBOOK NO FAN DISPSPLAY. BUT IT STILL CHARGES AND IF I PUT MY USB VOLT METER SHOW 5V AT USB WHENJ I POWER IT ON. IM STUMPED..
              11-21-2023, 02:51 AM
            • sidthesloth
              by sidthesloth
              by Vesko356
              08-11-2023, 03:27 AM
