Hey guys, need help figuring out this issue.
I received a HP mini 210 (DANM6AMB6F0 REV:F ) with no display issue. After troubleshooting, issue was a bad chipset and some corrosion here and there. After replacing the chipset and cleaning corrosion, laptop boots fine with display.
So I cleaned the board in an alcohol bath (>95% IPA) to remove flux residue, dried it on a hot plate at 60C for a few minutes and allow the board to naturally cooldown like I always do.
However, the board does not display anymore, no HDD activity either and I have no idea why. All voltage rails are present and stable. I tried known good RAM and BIOS just in case it got corrupted but no luck either. I also checked the display connector for residue/broken tracks/pin and display cable connection etc.
Current draw is 7-8mA on standby and 420 - 500mA when running.
Edit: external display does not work either.
Any idea? Anything I am missing?
