HP pavilion 17-e101sl motherboard no turning on
  • Bad_IC
    • Aug 2021
    • 23
    • Sardinia
    Laptop Hp: 17-e101sl
    motherboard: DA0R63MB6F1
    REV: F
    I've a problem with this motherboard. At first, I have replaced the diode on the input of board because was shorted and now it's possible to have 19.5v. I've checked the entire rail of 19.5v and is it ok, checked the 3.3v on the bios chip and it's present as well as on the SIO chip and on the power on button. When I press that button, the voltage goes from 3.3v to 0 but the motherboard won't start. ACDET pin on PU5 BQ738 is 2.7v.The laptop doesn't have the battery.
    Can it be a bios or SIO chip problem?
    Could someone help me please?
    Many thanks.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP pavilion 17-e101sl motherboard no turning on
    Check PU6 pin 13 & 15 for voltage.Pin4 & 20 for PU5. Check pin 9/67/93/95/127/76/65.
    Do check LID SWitch. These are basic steps to check. Let us see your readings and then we'll proceed further. Flash known good bios.
    • Bad_IC
      • Aug 2021
      • 23
      • Sardinia
      PU6
      pin 13→12.3v
      pin 15→0v
      PU5
      pin 4→25.3v
      pin 20→19.4v
      SIO
      pin 9→3.36v
      pin 67→3.36v
      pin 93→0v
      pin 95→0v
      pin 127→3.37v
      pin 76→3.01v
      pin 65→2.68v
      LID switch → sorry, but i can't find it on the board
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        PU6, pin15 is PowerGood and its pulled from AC_IN signal. Check whether you have it on pin5 of charging IC(PU5) as well as pin16 for REGN voltage. RSMRST# is missing on SIO-On some mb's it appears after switching but AFAIK it should be present before power on on this platform.
        If you have 3V on pin5 of PU5, proceed to replace PU6.
        • Bad_IC
          • Aug 2021
          • 23
          • Sardinia
          I've another identical motherboard just for spare parts that powers on and checked:
          PU6
          pin15 →0v
          PU5
          pin5 → 3v
          pin16 →6.05v
          Those voltages are the same on the motherboard that won't power on.
          Have I to replace PU6?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            PU6 pin15 must be 3V. The other board too have defective PU6-so replacing it from that mb wont help.
            • Bad_IC
              • Aug 2021
              • 23
              • Sardinia
              Ok.
              I've bought the new pu6 (g5934).I'll let you know as soon as I get and replace it.
              Thanks.
              • Bad_IC
                • Aug 2021
                • 23
                • Sardinia
                Hi mcplslg123,
                I've replaced PU6 with a new one, but the motherboard doesn't power on.
                Checked PU6 pins but the voltages are as the previous:
                PU6
                pin20 →19.5v
                pin15 →0v
                pin13 →12.3v
                PU5
                pin20 →19.7v
                pin4 → 25.4v
                pin5 → 3v
                pin16 →6v
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Check LIDSW# pin on SIO if you cant locate LID Switch.Dc jack light is stable and glowing?? Do you have dc power supply?? If yes, then what is the consumption in off stae?? Any change in dc reading when you try to turn on??Have you checked RTC circuit?? Next need to check Power Good signal.
                  • Bad_IC
                    • Aug 2021
                    • 23
                    • Sardinia
                    Sorry, but i can't locate LIDSW pin on SIO.
                    Dc jack is stable and glowing. On off state the consumption is 0.02 Amps, when I try to turn on it is 0.04 Amps. How can i check the RTC circuit?
                    I've attached some pics.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Pin25 EMU_LID & Pin127 LID_EC# on kbc. Locate jumper J1 & J2 and check them with a good cmos cell inserted but no power connected. What is the reading on both these jumpers?? The J1/J2 jumper is for RTC circuit check. Since there is slight change in dc reading, it could be RTC fault.
                      • Bad_IC
                        • Aug 2021
                        • 23
                        • Sardinia
                        pin25 EMU_LID→0V
                        pin127 LID_EC#→3.37V
                        J1→2.36V
                        J2→0V
                        I've Checked capacitor c905 on RTC section and it is short to ground; checked the same cap on the spare motherboard and it is no short.
                        I think that c905 is damaged and i have to replace it.
                        ok, replaced c905, now the readings are:
                        J1→2.64v
                        j2→2.64v
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Nice to see you fixed RTC fault. Voltage at J1/J2 seems fine now-so we can assume more or less that RTC section is fine though there are many other things to check on RTC but we left that for now.
                          AFAIK, EMU_LID is just another name of LIDSW#. If that is correct it must be 3V. You need to find out where the lidswitch is located. Most likely on powerbutton board. BTW, you are turning on the mb with power switch connected?? If yes, then remove the power switch board and check EMU_LID voltage again.
                          • Bad_IC
                            • Aug 2021
                            • 23
                            • Sardinia
                            LIDSW→3.35V (please see attached pic)
                            Removed the power switch board, EMU_LID (pin25 SIO)→0V (see pic)
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Oops, it seems like LID_EC# is what is popularly called LIDSW# and that;s reaching the SIO. So everything seems fine with LIDSWitch.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Check ECRST on pin37/AC_IN on pin76/RSMRST# on pin95/EC_PWROK on pin93/HWPG on pin14 of SIO. Notice the change,if any, on NBSWON#/DNBSWON# pins of SIO while triggering the mb. IS there any change in consumption on your dc supply before/after switch on??
                                • Bad_IC
                                  • Aug 2021
                                  • 23
                                  • Sardinia
                                  pin37 ECRST→3.35V
                                  pin76 AC_IN→3V
                                  pin95 RSMRST→0V
                                  pin93 EC_PWROK→0V
                                  pin14 HWPG→0V
                                  When power switch button is pressed:
                                  NBSWON→from 3.36V to 0.00V
                                  DNBSWON→remains to 0V nothing happens
                                  Power supply consumption:
                                  from 0.02A to 0.04A when power switch button is pressed.
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    I dont have any more ideas friend but i'll suggest to replace SIO chip.
                                    • Bad_IC
                                      • Aug 2021
                                      • 23
                                      • Sardinia
                                      Thank you so much for your time and your valuable advice. I'm very busy now, if i get the chance to replace the SIO, i'll let you know.Thanks.
                                        HP Pavilion Pavilion Laptop 14-dv2514sa Notebook 14 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Pavilion Laptop 14-dv2514sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2514sa boardview and Pavilion Laptop 14-dv2514sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                        09-07-2024, 05:50 AM
                                        HP Pavilion Pavilion Laptop 14-dv0631sa Notebook 14 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Pavilion Laptop 14-dv0631sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0631sa boardview and Pavilion Laptop 14-dv0631sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                        HP Pavilion Pavilion Laptop 14-dv2513sa Notebook 14 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Pavilion Laptop 14-dv2513sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2513sa boardview and Pavilion Laptop 14-dv2513sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                        HP Pavilion Pavilion Laptop 14-dv0569sa Notebook 14 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Pavilion Laptop 14-dv0569sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0569sa boardview and Pavilion Laptop 14-dv0569sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                        HP Pavilion Pavilion Laptop 14-dv0632sa Notebook 14 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Pavilion Laptop 14-dv0632sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0632sa boardview and Pavilion Laptop 14-dv0632sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
