Acer No power A4WAB LA-C341P REV 1.0
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Re: Acer No power A4WAB LA-C341P REV 1.0
    Originally posted by mon2
    PR316 is bad.
    Power down and check the resistance of this resistor.
    I tried to check the resistor by removing it outboard I got the exact value 316k but after putting it back to the board Ive lost the 3.3v to the pin 2 of PR316
    Checking the pin 10 of PU301 ilim- 0v
    • mon2
      • Dec 2019
      • 14118
      Check pr317 and the cap pc320. One of these must be shunting the voltage to ground. If the ic is soldered ok and is not defective then this rail should not be zero volts.
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        Resistor shows 87 kilo ohms out of the board
        the caps is not shorted
        • mon2
          • Dec 2019
          • 14118
          Then the ic must have a short. This pin is an input and the external resistor voltage divider must present a non-zero value to denote the max amount of current for this regulator.
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            I need to change the BQ24735RGRR ? pu301
            • mon2
              • Dec 2019
              • 14118
              1) PR317 should be 100k 0402 1% tolerance.
              2) Based on the same page in the schematic, with 100k & 316k voltage divider using +3VALW, this configures this charger IC to support 3.966A of current.
              This will only occur if there is a non-zero value at the middle junction of these 2 resistors.
              Currently (no pun) you have 0 volts at this common pin # 10 (ILIM).
              3) Confirm that the pin #10 of PU301 is not shorting to something else under the chip. Perhaps even consider to flux and reflow this IC. Then check the voltage on this pin again.
              4) Aside from the above, believe that you should consider sourcing a fresh IC and replace this PU301 and then test again.
              5) As a test, you can remove PU301 but also remove PL302 and then power up and check the voltage at the pad for Pin # 10.
              Based on the 2 resistor values, this pin must be a non-zero voltage value.
              I would also source a 100k 0402 1% resistor to replace the 87k one on the logic board.
              The reason to remove the PL302 is to prevent any voltages from being sent downstream in the absence of this PU301 IC. Thought is that PU301 is now strapping the Pin #10 to ground, either due to a solder short and internal defect.
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                #27
                I tried the option to remove the PU301 and the PL302
                Checking voltage at
                PQ302
                5. 19V
                1,2,3, - 0V
                4 -0V
                PIN 10 of pad #10 0v
                maybe it has no voltage beacause it wont allow the PQ302to passs the 19v?
                • mon2
                  • Dec 2019
                  • 14118
                  No. If the 316k is mated to +3v3Alw which it is and the 100k is truly to ground (confirm this) then you have a resistor based voltage divider. For this reason, this cannot be 0 volts unless one of these resistors is defective or not as connected in the schematic.
                  Google "resistor voltage divider calculator" and punch in the 3.3 volts; 316k, 100k value to see the expected voltage value.
                  https://ohmslawcalculator.com/voltag...der-calculator
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    #29
                    trying to reflow the resistors then tried a new reissitor same issue no 3.3v present
                    • mon2
                      • Dec 2019
                      • 14118
                      Check the resistance on the 100k resistor. Is it zero ohms at the pin that mates with the 316k?
                      Is the other pad of the 100k really mated to ground?
                      Remove the cap in this area to rule out the cap as a short.
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        #31
                        Yes everything is mated to ground the cap was remove then tried to plug power no voltage reading again to the resistors
                        • kalilinux25
                          • Mar 2018
                          • 2089
                          • ZAMBOANGA SIBUGAY
                          #32
                          I now tried to change thePU301 blinking LED at the power led the charging light and the blue light its taking only 6 amps unstable..
                          PQ302
                          pin 1- 0v
                          pin 2-4- 0v
                          pin 5 20v
                          PU301
                          PIN 1 -20V
                          PIN 2 - 20V
                          PIN 3 - 10-11V not stable
                          PIN 4 - 11, 12, 13 not stable
                          pin 5- 1v not stable 1.1v
                          pin 6 - 2.7v stable
                          pin 7 -0v
                          pin 8 - 3.3v
                          pin 9 - 3.3v
                          pin 10 - 0v
                          pin 11- 24v
                          pin 12 - 20v
                          pin 13 - 20v
                          pin 14 - 0v
                          pin 15 - 0v
                          pn 16 - 6.0v stable
                          PIN 17 -20V STABLE
                          PIN 18 - 20V STABLE
                          PIN 19 - 20V
                          PIN 20- 20V
                          PL402 - 3.3V
                          PL404 - 5V
                          • Sametbey
                            • Jan 2021
                            • 229
                            • Turkey
                            #33
                            First of all, your AC power supply must be working properly. charge control voltages are in the picture. The IO needs to receive +3V LDO and AC_OK signal to work. By sending EC_ON after the IO AC_OK signal, +3v and +5v are activated. ILIM is not so important, it can be 0. If there is no short circuit in the +B19 line, the PU301 charge control voltages should be as follows.
                            I'm not happy to be so strong. because it's not humanly
                            • kalilinux25
                              • Mar 2018
                              • 2089
                              • ZAMBOANGA SIBUGAY
                              #34
                              Yes but Unit still no power sir why its causing it what to test and change\
                              • kalilinux25
                                • Mar 2018
                                • 2089
                                • ZAMBOANGA SIBUGAY
                                #35
                                Hi hope someone can help me?
                                  • 20795
                                  SW4 BI SW .Press the switch in .
                                  • kalilinux25
                                    • Mar 2018
                                    • 2089
                                    • ZAMBOANGA SIBUGAY
                                    #37
                                    how can I test it sir?
                                    • kalilinux25
                                      • Mar 2018
                                      • 2089
                                      • ZAMBOANGA SIBUGAY
                                      #38
                                      I already tried the switch same issue
                                      • kalilinux25
                                        • Mar 2018
                                        • 2089
                                        • ZAMBOANGA SIBUGAY
                                        #39
                                        If the board is plug without power press I only have 5V present @ PL404 I dont have 3V @ pl402 . Ive check resistance of PL402 around 3kilo ohms PL404 5KILO OHMS. If I press power it will produce a stable 3.3v and 5v but it only takes 8milliamps to 10 milliamps
                                        • kalilinux25
                                          • Mar 2018
                                          • 2089
                                          • ZAMBOANGA SIBUGAY
                                          #40
                                          Hi sir can you send me a clear image
                                            09-06-2024, 05:27 AM
                                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 05:00 AM
                                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:10 AM
                                            Acer Swift SF114-34-P2CV + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                                            This specification for the Acer Swift SF114-34-P2CV + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2CV + Pack Gold Acer 14'' boardview and SF114-34-P2CV + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-07-2024, 03:10 AM
