HP OMEN 15-dc0001ng no post
  • sagaris
    • Jun 2021
    • 15
    • Romania
    Hello forum, i have a problem with my hp omen , it`s a verry powerfull and capable laptop but for now it is not dead only in limbo i think ) . so...let me tell you what are the simptoms what happened and maybe someone cand get on the bottom of this because i just got to the point where the next step is to throw him out the window . Well so two months ago after i was working on him and then game some 2 hours i powered off and the second day when to power on blank screen 3 long caps lock lights and 2 short lights caps lock , then i just took out my old asus and start browsing these caps lock seems to be the ram and on hp says reseat the ram i did that 50 times nothink...then i find the information that the bios doesn`t comunicate with ram properly or bios corruption was in place. Good ...the i folowed instructios to wotk with windows+B or windows+v makeing a bios recovery stick nothink worked. i took the laptop to a repair shop those guys didn`t saw this kind of laptop in the shop and after 1 week called me to take the laptop back because they don`t know what was happening ...well i told them to close shop and go to the country side and go work on the fields or somethink ) and i took tha matter on my own hands ..i buyed a ch341 programmer and i got a bios dump from both chips the main one is a 25B127DSIG and second 25Q80CSIG both dumps had information on them so no FFFF. the motherboard is DAG3BMB8D0 REV: D the laptop powers up one cooler spins all the usb on the motherboard works i can charge my phone on them so current flows , the charger charges orange when charge white when full don`t ask for multimeter because i don`t have and i forgot how to use a multimeter from highschool )
    if someone cand make light on this matter and can help me i will apreciate all the info , thanks in advance .
  • peste
    • Dec 2016
    • 12755
    • ROMANIA
    Re: HP OMEN 15-dc0001ng no post
    make a new thread in the "bios requests only" section ... post the bios, name and full model of the laptop, and someone will help you there with that ..
    • sagaris
      • Jun 2021
      • 15
      • Romania
      thanks i posted there too in fact i don`t know exactly if is a bios problem
      • Andreja686
        • Jul 2021
        • Ukraine
        Добрый вечер, я не владею английским по этому напишу вам на родном языке. Если у вас есть микроскоп то проверьте пайку разъема оперативной памяти, это часто встречающаяся неисправность ноутбуков этой фирмы.
        Bonsoir, je ne parle pas anglais, je vais donc vous écrire dans ma langue maternelle. Si vous avez un microscope, vérifiez la soudure du connecteur RAM, il s'agit d'un dysfonctionnement courant dans les ordinateurs portables de cette société.
        • JoWed
          Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
          by JoWed
          Hello Community,
          I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
          07-01-2025, 09:32 AM
        • Dani Rahal
          hp omen 17-cb0247ng bios
          by Dani Rahal
          Hi can some one help me plz
          i have hp omen 17-cb0247ng (la h492p) it have bios problems and i flashed bios from usb the new one v53 and its boosting to bios but did not start to windows (blue screen of death) i tryed evry thig and not working
          i flashed bios with programer ( CH341A )and it will not boost to bios just fan working no disply now i flash the orginal bios back its working but no booting to windows same problem
          the bios from hp after extract have 4 bios file same size i tryed 4 of them not working
          i have the orginal bios if some one can see what the problem or...
          05-30-2025, 09:11 AM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • zerbatin
          HP Omen 16-c0825no BIOS.
          by zerbatin
          I have problem with my laptop. When I turn it on it do not POST. Black screen with FAN not working, When pressing CTRL+V/B I can go into BIOS update, but after auto restart there is no update screen. Nothing happen.
          I have tried using this DUMP but with no go,
          https://www.badcaps.net/forum/troubl...os#post3210916
          My winbond BIOS chip got fried as well after 4th attempt, now it is unsoldered and I am waiting for...
          07-17-2025, 02:14 PM
        • MDSI
          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
          by MDSI
          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
          Details:
          Model : HP OMEN 17-an012nf
          Motherboard Part Number : DAG3BAMBAF0 REV : F
          Serial Number (S/N) : 5CD7280D51
          BIOS chip : Winbond W25Q64VSIQ
          Programmer : EZP2023+
          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
          I already...
          07-28-2025, 07:11 AM
