MacBook Air A1466 not powering. Fan spin at very speed.
  • kalzabdul
    • Sep 2020
    • 28
    • Uganda
    Hi. I have an A1466, 820-3437-B not powering but there is corrosion around Q8150 and three resistors R8151, R8156, R8154 fell off due to the above.
    But when i short SOPGD_C to ground the fan spins very fast but no cpu power
    All S0 rails present except PPVCC_S0_CPU.
    Below are some other voltages I believe are involved in creating CPU vCore;
    All_SYS_PWRGD. • 0.95v
    SOPGD_C • 0.98v
    CPUVR_FCCM •2.36v
    CPUVR_BOOT • 4.85v
    CPUVR_PWM. •0.2v
    CPU VR_EN. •0v
    CPU_VR_READY •0v
    PP5V_S0_CPUVR_VDD •5v
    PPVIN_S0_CPUVR_VIN. •8.67v
    VMON_Q2_BASE •1.8v
    VMON_Q3_BASE •0v
    VOMN_Q4_BASE •0.7v
  • kalzabdul
    • Sep 2020
    • 28
    • Uganda
    Re: MacBook Air A1466 not powering. Fan spin at very speed.
    Is there any one with a clue, please it’s urgent
    • mon2
      • 13838
      hi. a lot of information is missing and more details are required.
      1) start with page # 49/76 of the pdf schematics.
      2) does your magsafe adapter light (green? orange?) stay on when applied to the computer? Are you using an orginal apple adapter? the clones are nasty and can be dangerous to the board. At the very least, if using a clone (not recommended), attach the magsafe adapter FIRST to the computer and then plug it in. We have seen sparks from the connector if docking a hot (clone) adapter. Crap designs from Asia.
      3) with the adapter attached, confirm the voltage reading
      @ PPDCIN_G3H. Value?
      @ D7005, pin #3. Value ?
      @ L7905, pin # 2. Value ? This rail must be stable @ +3v42 to power the critical components of the logic board.
      If this rail is not at this value, power down - remove battery / adapter - then use a meter to check the resistance to ground on L7905, pin # 2. Value ?
      @ PPBUS_G3H = F7140, pin # 2. Value ? If F7140 is zero, check pin # 1 of F7140.
      If this rail is not at this value, power down - remove battery / adapter - then use a meter to check the resistance to ground on F7140, pin # 2. Value ?
      In general, checking the resistance to ground of each grey coil is a good idea to quickly review if you are facing a bad capacitor on the logic board. We have fixed at least 3 A1466 units using this approach. A low resistance value is a reading that is < 10 ohms - then we can investigate further.
      • piernov
        • Jan 2016
        • 4435
        • France
        Originally posted by kalzabdul
        VMON_Q3_BASE •0v
        Missing/bad PP3V3_S0, R8154 or R8158.
        • kingskie
          Macbook Air A1466 820-00165 green light no fan spin
          by kingskie
          Hi All,
          I got macbook air 820-00165 with green light but no fan spin.
          Measurements:
          PPBUS_G3H = 8.14V
          PP3V3_S5 = 0V
          PP5V_S5 = 0V
          SMC_WAKE_L = 3.12V
          SMC_ONOFF_L = 3.4V
          SMC_RESET_L = 3.38V
          should i change the U7501 first?
          01-08-2023, 09:54 PM
        • psdavid65
          Macbook Air A1466 820-3437-B Booting Problem
          by psdavid65
          I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
          06-20-2024, 12:27 AM
        • echothegamer
          Macbook A1466 dies when charger disconnected
          by echothegamer
          Hello all,
          Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
          Details:
          Macbook 13' A1466
          Board (820-3209-A)
          Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
          Pictures below of Boardview and schematic...
          I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
          It's an older model and it is very likely that battery has become...
          10-28-2023, 12:00 PM
          Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
          This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
          09-07-2024, 02:20 AM
          Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
          This specification for the Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58LR boardview and Spin 3 SP313-51N-58LR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-06-2024, 09:30 PM
