HP Spectre x360 Quanta DAY0DDMBAE0
  • mferna14
    • Jun 2018
    • 1046
    Hi all, I am working on this Laptop HP Spectre x360 Quanta (Motherboard DAY0DDMBAE0). The problem before was the DC-in jack WHITE LED was blinking. Some web sites adviced to replace the battery. When replaced with original battery, it work for a few days & then the problem started again with a different symptoms. The LED light was blinking looong-short (via-versa) & the laptop does not turn on any more. Upon diagnostic I found that there is no 3.3v but 5v is 100% present. When the battery is plugged in, the LED turns WHITE to ORANGE.... I checked PU11 (Page 33) from where 3.3V is generated & all seem to be fine on the pins except no output voltage. I removed the coil PL17 & checked without the coil on the motherboard the voltage on pin 10 of PU11 is around 16v & then no 5 volts when PL17 is out. AD_ID show only 1.12v where as this voltage should be 3.3., is this normal?? . Your help will be much appreciated. Thanks is advance
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP Spectre x360 Quanta DAY0DDMBAE0
    AD_ID will not be 3.3V and at 1.2V its most probably correct. The value depends on the adapter wattage. Check the wattage requirement of this laptop first. On certain mb's , it needs 90W adapter and you get dc jack light blinking on turn on when 65W adapter is connected.
    • mferna14
      • Jun 2018
      • 1046
      Thank you so much "mcplslg123".. must say you are a great help. I just checked all the voltages according to the schematics & notice that PU11 that outputs 3.3 volts, there is no enable voltage on pin 1 where as there should be 3volts & this pin 1 has only .16 volts. The similar chip by the side of it which generates 5v have the enable signal on pin 1 & I am assuming that this is why I have a clear 5v & because of the enable volt not present on pin 1 of PU11, 3.3v no output. On this same chip I am getting all the required voltage., pin 5 = 3.3volt., Input = 19 volt. The enable signal is coming from the ITE I/O chip. Can you pls. verify this for me. Thanks for the help.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        can you please attach the schematic?? This mb is likely to have DSW(Deep Sleep Well)-so mb will be in DSW stage offline and you are not expected to have +3/5VALW rails. Those will come up only after power on. Can confirm that only after seeing the diagram.
        PS: I still suspect it's a adapter issue-may be under rated or defective. Dc jack led is glowing white to red with battery does indicates battery is communicating with sio chip. May be the new battery is totally discharged and thats why its not turning on anymore from battery. Since it was working fine with new battery i dont think 3v regulator PWM is defective. If you have any option get the battery charged on another laptop and check again.
        • mferna14
          • Jun 2018
          • 1046
          I think "mcplslg123" you mis-read something. Actually this motherboard never turned on, with or without battery. I informed you that when I insert the battery only the DC-in jack LED turns white to red. It has not turned on & I am not getting 3.3Volts at all but I am getting 5v. I have attached the schematics & boardview for this motherboard to review., pls. help, thanks for all the cooperation.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            @mferna, Sorry for the misunderstanding. So S5_ON is not coming up and without this there will be no +3VALW. This signal comes from KBC. Do you have a kbc programmer as this kbc needs programming?? Have you flashed main bios yet?? Resistance on S5_ON is not low??
              HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) 13 Specification for Upgrade or Repair
              This specification for the HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 13-aw0197tu boardview and Spectre x360 - 13-aw0197tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              09-06-2024, 12:10 PM
              HP Spectre x360 Spectre x360 Conv13-aw0054na Hybrid (2-in-1) 13 Specification for Upgrade or Repair
              This specification for the HP Spectre x360 Spectre x360 Conv13-aw0054na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 Conv13-aw0054na boardview and Spectre x360 Conv13-aw0054na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
              09-06-2024, 11:50 AM
              HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) 15 Specification for Upgrade or Repair
              This specification for the HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-df0068nr boardview and Spectre x360 - 15-df0068nr schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              09-06-2024, 07:20 AM
              HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
              This specification for the HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-ch050na boardview and Spectre x360 - 15-ch050na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              09-06-2024, 06:21 AM
              HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) Specification for Upgrade or Repair
              This specification for the HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Spectre Tech Tote boardview and 1030 G4 + Spectre Tech Tote schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
              09-06-2024, 11:39 AM
