A1502 820-3476 Works but no fan spin
  • mon2
    • Dec 2019
    • 14677
    Hi. Just received an A1502 (820-3476) that had a damaged LCD panel. The panel has been replaced, unit works fine - chime and all but have yet to see the fan turn on. Not a good sign. Temp is about 40 degrees C on the heatsink.
    Will check the mosfet @ Q6060 that is responsible for motor control (J6050).
    Have attempted PRAM reset - no difference. The fan / logic board look mint with no dust, no liquid damage / no liquid indicator triggers.
    Any suggestions?
    Update - fan just turned on via diagnostics. Perhaps a non-issue and the logic board was cold enough as to not trigger the fan?
    Please ignore (unless you believe this board is not behaving correctly).
  • Offscreen6
    • Jan 2021
    • 22
    Re: A1502 820-3476 Works but no fan spin
    Perhaps there is a loose connection somewhere between the fan and the main PC, that keeps it from starting up on boot. Definitely check that the main connector from the motherboard to the fan is properly fitted.
    I don't know how you could check if it is a non-issue without just letting it run for long enough until you'd imagine the fan should kick in... of course, that risks overheating the computer.
    For some more help, I found this guy working on the same computer, with the exact opposite problem; the chime works but not the fan. I'm no motherboard expert, but maybe that can give you some insight : https://boards.rossmanngroup.com/thr...o-chime.36617/
    • piernov
      • Jan 2016
      • 4439
      • France
      Are you 100% sure this is a 3476 and not a 4924? If yes run ASD to make sure the fan motor tests and CPU warm-up tests pass.
      • mon2
        • Dec 2019
        • 14677
        Hello. Thank you both for your replies.
        1) No, we are not 100% confident of the board # as we could not locate the PCB etched markings on the topside (after the bottom lid is removed). The boardview locations for the LVDS, battery connector, fan connector all match the 820-3476.
        2) Did run ASD and the tests passed. The ASD testing process enabled the fan spin. The fan connector is factory tight - no one has been inside this machine before us. There is a large block bump pad on the fan FPC cable. Guessing it is to lift up the bottom lid and serves no other purpose.
        Just somewhat baffled that the logic board boots upon turn on and does so without a fan spin. Used to fan spin upon power on cycle.
        So, is it normal to not have the fan spin on power up (like all other inspected macbooks to date) for this A1502? It is our first A1502 in the shop.
        • piernov
          • Jan 2016
          • 4439
          • France
          3476 is a 2013 model and has 16 RAM chips without shield over them. (and there's also the 3536 2013 model with 8 RAM chips without shield over them) Model number is near RIO board connector.
          4924 is a 2015 model and has 4 RAM chips with shield over them.
          You must confirm the board model number or at the very least the full machine model number before troubleshooting as indicated in the Beginner's guideline, you can't troubleshoot something if you don't what it is, and if you give incorrect numbers it just makes everyone waste their time.
          • ACS-Repair
            • Feb 2021
            • 204
            I too was trolled by an A1502 where the fan would not come on at startup. Mine was an 820-4924 that would come on and run for long periods without the fan. I loaded the Macs Fan Control app so that I could see the fan speed and the CPU temps. I could manually turn the fan on with the app so I could see that it was not a problem. For some reason this model will stay cool without the fan.
              Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
              This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
              09-07-2024, 02:20 AM
              Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
              This specification for the Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58LR boardview and Spin 3 SP313-51N-58LR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-06-2024, 09:30 PM
              Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
              This specification for the Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58JR boardview and Spin 3 SP313-51N-58JR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) 3 Specification for Upgrade or Repair
              This specification for the Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP314-54N boardview and Spin 3 SP314-54N schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 07:50 PM
              Acer Spin SPIN 1 SP111-33 Hybrid (2-in-1) 1 Specification for Upgrade or Repair
              This specification for the Acer Spin SPIN 1 SP111-33 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SPIN 1 SP111-33 boardview and SPIN 1 SP111-33 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 08:40 AM
