It8528e kbc Inspiron 15-7547 (MB DA0AM6MB8F1 Rev F)
  • mferna14
    • Jun 2018
    • 1018
    Hi all., I am working on a Dell Inspiron 15-7547 (MB DA0AM6MB8F1 Rev F). The problem is with the keyboard. Some keys on the keyboard are not working. Replaced with a brand new known good keyboard, still the same, excatly the same array is not working. The KBC controller on this board is IT8528E. My question is, I have checked many forums & they say that this chip does not need programming. Is this ture & if not how will I program it???? Thanks in advance if someone can give me some answers.
  • master7
    • Mar 2017
    • 3
    • Brasil
    Re: It8528e kbc
    Hello, IT8528E is not programmable. If you see in the diagram of the board on page 41, U18 is the EC programming chip, that is, the IT8528E programming is external. It is always a good idea to use a keyboard test to see if the problem is really there. You can check or change the keyboard connector on the motherboard and test the tracks between the connector and the respective pins on the EC, if there is continuity between them.
    • mferna14
      • Jun 2018
      • 1018
      Re: It8528e kbc
      Thank you so much for the reply "master7". I thought it was programmable. As I told you before that I put in a brand new keyboard & the same keys not working. Now its night in Canada I cannot tell you surely which keys are not working but its the array of "P" "O" & more which I am sure are not working. I will surely check the continuity tomorrow & see whether all track are working or not. But can you confirm whether this IO Chip IT8528E controls the Keyboard?? Thanks
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Re: It8528e kbc
        Yes, the IO chip controls the keyboard and its not programmable. Go by the suggestions of @master7 and do check continuity between kbd connector and io chip. Check for any corrosion on tiny filter caps near kbd connector.
        • mferna14
          • Jun 2018
          • 1018
          Re: It8528e kbc
          Thank you very much for your suggestion "mcplslg123". Really appreciate!!! Is there any diagram to show which circuit lines controls what keys array on the keyboard?
          • mon2
            • Dec 2019
            • 14122
            Re: It8528e kbc
            hello from Windsor. pls see attached.
            • mferna14
              • Jun 2018
              • 1018
              Re: It8528e kbc
              Hi "Mon2" you guys are really GREAT... I have this photo & I know about this matrix... but I wanted to know the arrays MY1 ~ MY8, what keys on the keyboard do they control??? Thank you very much
              • mferna14
                • Jun 2018
                • 1018
                Re: It8528e kbc
                & one more thing should I just purchase a new IT8528E KBC Chip (NO NEED TO PROGRAM) & solder the new one on the board. Will it work fine. (This I will do after I check all continuity between kbd connector and io chip)
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Re: It8528e kbc
                  Yes, it will work as long as there is no other issues.
                  • mferna14
                    • Jun 2018
                    • 1018
                    Re: It8528e kbc
                    Thanks "mcplslg123" really appreciate... I checked all the all line for continuity between kbd connector and io chip, 100% ok. All these Keyb array lines & going to this IO contr'l. There are no other issue with the notebook except the few aplhabets on the keyboard are not working. I have ordered th chip, mine was IT8528E FXA (year 1414). Hopefully will get it soon & will surely report the progress. Thanks
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Re: It8528e kbc
                      Make sure to match the suffix FXA. Its important.
                      • iyan76
                        • Nov 2020
                        • 11
                        • Singapore
                        Re: It8528e kbc
                        Hai.. How was the progress, then.. Are you made it, solved the problem by replacing the KBC with the new one as is ?
                        • mferna14
                          • Jun 2018
                          • 1018
                          Re: It8528e kbc Inspiron 15-7547 (MB DA0AM6MB8F1 Rev F)
                          Yes, all worked & all keys worked too...
                          • iyan76
                            • Nov 2020
                            • 11
                            • Singapore
                            Nice fortune, then.
                            Me not that luck by the way.
                            I have replaced Yoga 300-11ibr with new IT8528 but not solved the problem still.
                            Keyboard not working at all, even on Bios state.
                            Anyone have idea ?
                            • Sephir0th
                              • Oct 2020
                              • 1282
                              You didn't mention whether you have already replaced the keyboard or not.
                              FairRepair on YouTube
                              • mferna14
                                • Jun 2018
                                • 1018
                                No need to replace the Keyboard, It was the I/O chip which was defective. Replaced it with a new one & all worked fine.
                                • Sephir0th
                                  • Oct 2020
                                  • 1282
                                  Yeah I know, I'm not talking to you but to ivan76.
                                  • iyan76
                                    • Nov 2020
                                    • 11
                                    • Singapore
                                    Ah.. thanks for mentioned me.
                                    Even this has been couple years, but I Still didn't solved this mistery. LoL
                                    Yes I have already replace with new Keyboard.
                                      DELL Inspiron 3268 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 3268 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3268 boardview and Inspiron 3268 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      09-12-2024, 03:44 PM
                                      DELL Inspiron 3650 Inspiron i7-6700 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      DELL Inspiron 3650 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                                      DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
                                      DELL Inspiron 3470 Inspiron 3000 i5-8400 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3470 boardview and Inspiron 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
