Microsoft surface Bitlocker - need help
  • basic
    • Oct 2017
    • 229
    • 86357289244
    hi friends
    i have a microsoft surface laptop model 1769 , and i have this problem which is first for me ..
    bitlocker recovery key
    i have try to reset but no succes ,
    what next to do any help
  • rediii
    h???, spurrrn
    • Mar 2018
    • 487
    • somewhere in europe
    Re: Microsoft surface Bitlocker - need help
    Originally posted by basic
    hi friends
    is the data important? if not, try to boot from an external device (usb stick) and wipe the ssd. just reinstall windows afterwards. if data is necessary you need the correct recovery key!
    • basic
      • Oct 2017
      • 229
      • 86357289244
      no the data are not important and i have try to fresh install windows 10 but i get this message error :
      DATA ERROR CYCLIC REDUDANCY CHECK
      • rediii
        h???, spurrrn
        • Mar 2018
        • 487
        does this error occur after the first reboot, directly after the windows installation? can you check the smart data of the ssd in a winpe environment?
        • basic
          • Oct 2017
          • 229
          • 86357289244
          i am not sure on first boot or after many try
          • basic
            • Oct 2017
            • 229
            • 86357289244
            i have dissasembly the surface to remove ssd but is soldered on board
            • rediii
              h???, spurrrn
              • Mar 2018
              • 487
              try to test the soldered ssd with tools (maybe hdat2, maybe win pe or linux)
              • basic
                • Oct 2017
                • 229
                • 86357289244
                i think the ssd is write and read protected .
                using cmd i saw the datentrager ist geschutzt .
                protected hardrive
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Looks like faulty hardware.
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                    • 20884
                    Win10 will only install if you disable secure boot and use "delete volume override" in DISKPART .Use a UEFI bootable flash drive.You can re-enable secure boot after the install .I reset my nieces surface 4 this way,she didn`t save her bitlocker key to onedrive.
                    https://www.repairwin.com/fix-cannot...ith-bitlocker/
                    • rediii
                      h???, spurrrn
                      • Mar 2018
                      • 487
                      mhhh, i did it without those steps, but yeah, just try it! good advice
                      • basic
                        • Oct 2017
                        • 229
                        • 86357289244
                        when i try delete volume override in diskpart i get error message
                        cyclic redundance error
                          • 20884
                          Run chkdsk see if that will fix it.
                          • basic
                            • Oct 2017
                            • 229
                            • 86357289244
                            i get now error the chkdsk can not continue ist read only
                            on list volume ist the unknow format . not ntfs or fat32
                            is just unknow
                              • 20884
                              My mistake i forgot it won`t run. You could try the Microsoft surface data eraser or a PSID Revert using the SSD tools from the drive manufacturer or use some other partition software.https://docs.microsoft.com/en-us/sur...ce-data-eraser
                              • basic
                                • Oct 2017
                                • 229
                                • 86357289244
                                i think this hardrive is protected coz even with cmd i didnt make to erase
                                so does this microsoft erase program will erase !!
                                  • 20884
                                  Try it,if it doesn`t work just google "PSID Revert" .What make/model is the drive ?
                                  • vishal24
                                    • Nov 2019
                                    • 23
                                    • India
                                    Is there any way to unlock bitlocker
                                    c drive lock, so windows lock. & i don't have Microsoft account
                                    pl. guide me
