Lenovo Ideapad 330 Onboard Memory Fail
  • memoslar
    • Apr 2015
    • 122
    • Greece
    I have a Lenovo Ideapad 330. The onboard ram has failed on memory test.
    Any help how to disable this and works only from the slot ram?
    Board is DG52A NMB244
  • memoslar
    • Apr 2015
    • 122
    • Greece
    Re: Lenovo Ideapad 330 Onboard Memory Fail
    Here i have the schematic..
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Schematic for A482 is same as B244?? Anyone can help you on that but without boardview its impossible to find the resistor which needs swapping/relocation. First post boardview , if you have one.
      • memoslar
        • Apr 2015
        • 122
        • Greece
        Maybe this schematic is wrong... I made a request in the site for the appropriate .. thanks in advance
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I've linked the boardview in schematic section. You can use NM-B241 schematic which is practically same as your mb. The ram config is given on Pg 8 of NM-B241 schematic. If you can understand do it yourself, else you need to specify the onboard ram detail -samsung,micron or hynix??
          • memoslar
            • Apr 2015
            • 122
            • Greece
            I read in memories k4a8g16. So it is samsung.
            Can you help what to do next?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              For onboard samsung memory shift RC1634 to RC1631 & Shift RC1635 to RC1632. The value of the resistor is same at 10K. So just needs shifting.
              • memoslar
                • Apr 2015
                • 122
                • Greece
                Oh my god thank you. i will do and inform you
                • memoslar
                  • Apr 2015
                  • 122
                  • Greece
                  Maybe i will need boardview to locate where are they, because i cant find them onboard... Is that possible?
                  • memoslar
                    • Apr 2015
                    • 122
                    • Greece
                    This is what i see near processor
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Read post#5. I've already linked the boardview file in schematic section .
                      • memoslar
                        • Apr 2015
                        • 122
                        • Greece
                        ok. i have done these steps. I have black screen. should i remove the old memories?
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          You can remove the onboard memory.
                          • memoslar
                            • Apr 2015
                            • 122
                            • Greece
                            I have no screen again.
                            Memories are K4A8g165wc bctd and i removed them
                            I checked again in microscope and there is samsung indeed
                            So the procedure is ok
                            I want to mention that i had first time black screen when i reflowed the old memories.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              @memoslar, seems like wrong diagnosis from the very beginning. If onboard ram was the issue, this would have been resolved. Your problem lies elsewhere. You have schematic+boardview. Check deeper.
                              • memoslar
                                • Apr 2015
                                • 122
                                • Greece
                                Thank you for your answer my friend. I tested with memtest without the external ram and showed errors. Also the laptop was freezing at random times. It was for sure the internal memory.
                                Something happened from reflow on memories....????
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Download bios update from lenovo site for your model and make a fresh bios out of it and flash it. If you dont know how to do that, ask for bios in bios section.
                                  • memoslar
                                    • Apr 2015
                                    • 122
                                    • Greece
                                    Ok it worked! thanks!!
                                    • krky
                                      • Mar 2020
                                      • Croatia
                                      THANKS!!! It worked on 320-17IKB Model: 81BJ with board EG521 EG522 EZ511 EG721 NM-B452 Rev-1.0.
                                      • gfr84
                                        • Jul 2021
                                        • Argentina
                                        I have a Lenovo Ideapad 330-15IKB. The onboard ram has failed on memory test with Memtes86+. Any help how to disable this and works only from the slot ram? memoslar, how did you get it working again? did you disolder the onboard ram?
