ACER ZRW no vcore after short to ground
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Hi good this the unit came with shorted problem ( PROBLEM SOLVE) change the PU5 (BQ24780SRUYR) also the PU6 (AOZ5029QI-5) The unit will power taking 400 milliamap ( outboard)
    I hope someone can guide me where to start finding the faulty parts to solve this issue
  • jermac0711
    • Jun 2022
    • 74
    • Philippines
    Re: ACER ZRW no vcore after short to ground
    I have the same problem. The whole VN line is completely shorted. I replaced BQ chip but still no luck. I hope an expert could shed some light for us.
    • adelfr2009
      HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
      by adelfr2009
      I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
      After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
      09-28-2025, 10:21 PM
    • playit
      450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
      by playit
      hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
      09-02-2023, 02:43 AM
    • mgrharry
      Acer Predator Helios 300 Short to ground
      by mgrharry
      Acer Pred Helios PH315-53-72XD with short to ground. Power adapter is also bad. Trying to determine where to inject voltage. Photos attached. Thanks....
      11-04-2022, 06:18 PM
    • Leefreeman97
      Diagnosing short to ground issue. pcb from an e scooter
      by Leefreeman97
      Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?
      09-19-2025, 03:33 PM
      09-06-2024, 05:27 AM
